08-08-2017, 17:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 356508 Status: Offline Thanks Meter: 132 | Telenor xt50 Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Elapsed: 00:00:08 how to unlock this phone , THX BR PS.SP Unlock buton is not active |
08-10-2017, 16:50 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Had checked that one, unfortunately it hardlocked, need make FW patch. We haven't finished yet unlock via direct patch, so can't say exactly ETA. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
03-10-2018, 12:53 | #6 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Possible to unlock this one..its have remains 5 attempt for unlock SPD module v 1.27 logs Code: Set mode to : SPD6531 Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : Telenor Model Name : XT50 ExtInfo Data : English Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_English__Telenor-XT50.bin Done! Elapsed: 00:01:27 Reconnect Power/Cable! Code: Operation : Read NVM [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Reading NVM .. NVM details : IMEI[1] : 866790022xxxxxx IMEI[2] : 352751019xxxxxx BT_ADDR : F808652E5E25 Read Ok! Saved to : C:\Users\D\Desktop\00400000_NVM.nv Done! Elapsed: 00:00:37 Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Read Ok! Saved to : C:\Users\D\Desktop\FLASH_DUMP.bin Done! Elapsed: 00:01:45 Telenor XT50 |
