08-08-2011, 12:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: UK
Member: 1515513 Status: Offline Thanks Meter: 11 | Tesco-Mobile-Mojo-Chat Unlock Procedure Its a great help if u share. Thanks !!!!! |
08-08-2011, 12:47 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
08-13-2011, 16:27 | #5 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | make a picture for every users Hi suppoprter.. please make a pinout picture for infinity users..becouse most people haven't pin finder..so that will help for all infinity users Thanks George |
08-13-2011, 17:22 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | cable: L12C 1x12 keyboard top 1............12 6: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 7: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) |
08-20-2011, 10:25 | #8 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Scotland, UK. Age: 43
Member: 83741 Status: Offline Sonork: 100.1624702 Thanks Meter: 88 | Quote:
WBR | |
08-20-2011, 13:49 | #9 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
but if you have PinFinder you can set pinout in manual mode, w/o automatic detection - it's fast and stable method. | |
08-20-2011, 22:53 | #10 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | COM70 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: Tesco-Mobile-Mojo-Chat Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: MOJO_CHAT_C200UK_V3.5_110616 Version: 86 byte(s) read imei: 35762804025100 connection Ok 192 byte(s) read reading data... building new data... writing data... 180 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! tested with local sim and ok if local sim is not registered or expired mojo will say invalid sim |
The Following 2 Users Say Thank You to mrfixit For This Useful Post: |
08-26-2011, 12:44 | #11 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | I have no idea about pinfinder! Any way to give us a clear idea of how to make the cable for it? I have no idea what an L12C cable is either! I got an old T191 one can I modify that for example? Thanks |
08-26-2011, 15:02 | #12 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
keyboard top 1.........12 6: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 7: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) | |
08-28-2011, 17:08 | #13 (permalink) |
Registered User Join Date: Jan 2005 Age: 46
Member: 111373 Status: Offline Thanks Meter: 25 | MOJO CHAT TP Unlock Procedue For those that cant get hold of a PIN Finder cable etc, the handset can be unlosked simply using a RJ45 cable, ann solidering to the TP under the screen. RJ45 PIN3 - TX on PCB RJ45 PIN2 - RX on PCB RJ45 PIN8 - GND on PCB Than sinply select Smart Fast method and unlock COM16 [VCP0] selected module v4.00 Action: "sp-unlock" unlock method: smart fast Model: Tesco-Mobile-Mojo-Chat Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: MOJO_CHAT_C200UK_V3.5_110616 Version: 86 byte(s) read imei: 35762804027846 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! Hope this helps those that cant get hold of the cables. Regards RajSE |
The Following User Says Thank You to rajSE For This Useful Post: |
08-29-2011, 23:18 | #14 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | Soldering to a testpoint under the screen? Can you upload a photo please for us non cable experts! I've always just bought them!! Thanks for your help anyway |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
