12-30-2008, 17:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | test reports huawei t161L and konka c625 Huawei-T161L COM25 [VCP0] selected module v1.59 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\mobile\infinity box\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20081230-214319.B1E.bin loading data... data loaded reading eeprom-security... file saved: E:\mobile\infinity box\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20081230-214320.B1E.bin reading eeprom-complete... file saved: E:\mobile\infinity box\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20081230-214321.B1E.bin reading additional data... file saved: E:\mobile\infinity box\InfinityBox\Pana01\Huawei-T161L_lock-area_20081230-214325.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 27 sec Remove/Install battery now ! br. Konka-C625 COM25 [VCP0] selected module v1.30 Device: Konka-C625 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89887200010001:89887200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb imei: 3570390127238690 Check hardware done Read data ... reading Konka-C625_3570390127238690_eeprom_calibration-1... warning: wrong data size at 0x06387400, retry... warning: wrong data size at 0x06387400, retry... warning: wrong data size at 0x06387400, retry... file saved: E:\mobile\infinity box\InfinityBox\HModule\Konka-C625_3570390127238690_eeprom_calibration-1_20081230-215918.80E.bin error: operation failed Finished, time used: 18 sec Remove/Install battery now ! ==== log: [12/30/2008 9:59:21 PM] ==== COM25 [VCP0] selected module v1.30 Device: Konka-C625 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... rom version: 0502 booting... Boot fail error: operation failed Finished, time used: 37 sec Remove/Install battery now ! ==== log: [12/30/2008 10:00:04 PM] ==== COM25 [VCP0] selected module v1.30 Device: Konka-C625 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89887200010001:89887200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb imei: 3570390127238690 Check hardware done Read data ... reading Konka-C625_3570390127238690_eeprom_calibration-1... file saved: E:\mobile\infinity box\InfinityBox\HModule\backup\Konka-C625_3570390127238690_eeprom_calibration-1_20081230-220105.80E.bin Read data done Check data ... simlock structure #1 pass-1... Check data done Write ... flash: 89887200010001:89887200000000 Write: eeprom Write done Finished, time used: 77 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmbac For This Useful Post: |
12-30-2008, 17:55 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
UNLOCK ALL MODEL Huawei T158B,Huawei T156B,Huawei T161L,Huawei,KENYANS CONTACT ME NOW | hassanjinja1 | Main Sales Section | 0 | 10-22-2009 13:45 |
please help me how to flash and unlocking konka c625 | noey | Infinity-Box | 1 | 10-21-2009 22:23 |
@INFINITY TEAM i Have KONKA c625 | JammerTwo | Infinity-Box | 6 | 07-30-2008 13:06 |
konka C625 and C636 | men | Various | 6 | 06-17-2008 11:35 |
