Tested Solution for Sigmatel "Not Calibrated"- 1 Attachment(s) Here Iam posting tested solution for Sigmatel S88 "Not Calibrated" problem which usually comes after formatting the phone. Just write the attached eeprom file and after writing the file do "Calibrate Touchscreen" in "mode-auto" with Infinity Box. Here is the log- Writing eeprom- ==== [21/03/2010 10:05:20 PM] ==== COM6 [VCP4] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00[1].T600_V04_ENFRARRUSPPEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CF03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\T600_V04_PCB01_GP RS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ff s_20100321-220712.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 11 sec Remove/Install battery now ! Touch Calibration log- COM6 [VCP5] selected module v3.11 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__fullflash_20100321-215302.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CF03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: T600_V04_EnFrArRuSpPeVi_SIGMATEL Version: T600_V04_HW 67 byte(s) read imei: 3523660****** connection Ok 512 byte(s) read 211 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 10 sec Remove/Install battery now ! Hope it will help a lot to all Infinity users.:) P.S.- I have tested this for only Sigmatel S88 model but I think it will work in some more models. I will update this thread as I will test with more sigmatel phones. Wr. |
great contribution thanks |
1 Attachment(s) Sigmatel S98 "Not Calibrated" solved- ==== [24/03/2010 3:33:58 PM] ==== COM6 [VCP1] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8303:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\T600_V04_PCB01_GP RS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ff s_20100324-153546.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 15 sec Remove/Install battery now ! Set is working fine after this. Wr. |
module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs error: no data loaded for Firmware i got the same problem whats this error |
which file you trying to load? |
SIGMATEL__Sigmatel-s88.B0E.rar which is shown above by PASSIONATE_BOYS |
Don't forget to take backup of full flash for emergency case before doing anything. Wr. |
Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00[1].T600_V04_ENFRARRUSPPEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7E6A:C9E3 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__ffs... error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: D8 Probably errors exist during flash read operation. Do you want to repeat read operation ? file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100327-172120.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 8 sec Remove/Install battery now ! done but the problem is same ...................... not calabrated |
Try with S98 eeprom file and post result. Wr. |
module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7E6A:C9E3 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 error: no any expected answer : wrong answer after chip cfi request flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... error: unexpected termination/freez: 00000000 search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__ffs... file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100327-182203.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done same problem not calabrated |
hello! show what error gives mode-auto of "calibrate touchscreen" post full log |
Try with latest Chinese miracle v3.11. Wr. |
module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7E6A:C9E3 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__ffs... file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100329-094637.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 25 sec Remove/Install battery now ! but also the same not calabrated |
i wrote anoter eprom also problem is same not calabrated my problem is Not Calibrated"- module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00[1].T600_V04_ENFRARRUSPPEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7E6A:C9E3 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__ffs... file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100329-095137.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 40 sec Remove/Install battery now ! |
hello guys! I just dont udnderstand why you need to solve this problem by eeprom writing. please try Calibrate touchscreen in "mode-auto" and problem must be solved. please post this log here |
