Old 03-21-2010, 18:02   #1 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,887
Cool Tested Solution for Sigmatel "Not Calibrated"-
Here Iam posting tested solution for Sigmatel S88 "Not Calibrated" problem which usually comes after formatting the phone. Just write the attached eeprom file and after writing the file do "Calibrate Touchscreen" in "mode-auto" with Infinity Box.
Here is the log-
Writing eeprom-
==== [21/03/2010 10:05:20 PM] ====
COM6 [VCP4] selected
module v3.11
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
T600_V04_PCB01_GPRS_MT6225_S00[1].T600_V04_ENFRARRUSPPEVI_SIGMATEL__Sigmatel-s88.B0E.bin
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:CF03:0006
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN
project-id: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\T600_V04_PCB01_GP RS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ff s_20100321-220712.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
sec info (fast) detection...
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 3 min 11 sec
Remove/Install battery now !
Touch Calibration log-
COM6 [VCP5] selected
module v3.11
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__fullflash_20100321-215302.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: T600_V04_EnFrArRuSpPeVi_SIGMATEL
Version: T600_V04_HW
67 byte(s) read
imei: 3523660******
connection Ok
512 byte(s) read
211 byte(s) read
reading data #2...
512 byte(s) read
calibration value: 0
writing data...
verification...
verification Ok
Finished, time used: 10 sec
Hope it will help a lot to all Infinity users.
P.S.- I have tested this for only Sigmatel S88 model but I think it will work in some more models. I will update this thread as I will test with more sigmatel phones.
Wr.
The Following 10 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-23-2010, 08:41   #2 (permalink)
Member: 399172
Sonork: 100.1581353
Thanks Meter: 81
great contribution thanks
Old 03-24-2010, 14:56   #3 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,887
Sigmatel S98 "Not Calibrated" solved-
==== [24/03/2010 3:33:58 PM] ====
COM6 [VCP1] selected
module v3.11
Action: write flash
skip: Firmware
skip: Customization
write: Eeprom/ffs
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88.B0E.bin
====> Boot ...
19200 autodetect
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:8303:0002
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\T600_V04_PCB01_GP RS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ff s_20100324-153546.B0E.bin
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization Done
Finished, time used: 3 min 15 sec
Set is working fine after this.
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-26-2010, 09:52   #4 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
module v3.07
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
error: no data loaded for Firmware
i got the same problem whats this error
Old 03-26-2010, 16:25   #5 (permalink)
Member: 148515
Thanks Meter: 14,623
Originally Posted by ashokassag View Post
module v3.07
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
hello!
which file you trying to load?
Old 03-27-2010, 05:40   #6 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
SIGMATEL__Sigmatel-s88.B0E.rar
which is shown above by PASSIONATE_BOYS
Old 03-27-2010, 12:18   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,887
Uncheck Firmware, Check on Eeprom/ffs option, press load Eeprom/ffs, select file and press Write.
Don't forget to take backup of full flash for emergency case before doing anything.
Wr.
Old 03-27-2010, 13:17   #8 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
Action: write flash
skip: Firmware
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:7E6A:C9E3
status: FF
high speed boot Off
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
interesting cpu type found
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
rom info ver: 04
sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN
project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__ffs...
error: no any expected answer
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
error: wrong answer: D8
file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100327-172120.B0E.bin
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization Done
Finished, time used: 6 min 8 sec
done but the problem is same ...................... not calabrated
Old 03-27-2010, 13:43   #9 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,887
Try with S98 eeprom file and post result.
Wr.
Old 03-27-2010, 13:56   #10 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
module v3.07
Action: write flash
skip: Firmware
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
error: no any expected answer : wrong answer after chip cfi request
flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
error: unexpected termination/freez: 00000000
file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100327-182203.B0E.bin
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
same problem not calabrated
Old 03-28-2010, 06:13   #11 (permalink)
Member: 148515
hello!
show what error gives mode-auto of "calibrate touchscreen"
post full log
Old 03-28-2010, 07:52   #12 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,887
Try with latest Chinese miracle v3.11.
Wr.
Old 03-29-2010, 05:19   #13 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
module v3.11
Action: write flash
skip: Firmware
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100329-094637.B0E.bin
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization Done
Finished, time used: 2 min 25 sec
but also the same not calabrated
Old 03-29-2010, 05:23   #14 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
i wrote anoter eprom also problem is same not calabrated my problem is
Not Calibrated"-
module v3.11
Action: write flash
skip: Firmware
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Documents and Settings\Ashok\Desktop\T600_V05_PCB01_GPRS_MT6226_ S01.T600_V05_ENFRARRUSPPEVI_SIGMATEL__ffs_20100329-095137.B0E.bin
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization Done
Finished, time used: 2 min 40 sec
Old 03-30-2010, 04:51   #15 (permalink)
Member: 148515
hello guys!
I just dont udnderstand why you need to solve this problem by eeprom writing.
please try Calibrate touchscreen in "mode-auto" and problem must be solved.
please post this log here
1000000000000% tested solution for emergency mode for w339 lalitjsraks Various CDMA/TDMA Cell Phones 1 09-18-2009 08:14
Atlast i got the solution for Sigmatel S4 flight mode arifraj Chinese Models & Cloned Phones 1 09-20-2008 13:39
Solution for repair "not power on" phone T100 - free!!!!!!!!! sed_alex VLSI, Conexant, Skyworks and Old Models 2 09-30-2002 22:36
Tested solution for Games and Tones freezing kingbode Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 02-16-2002 16:51
tested solution for N105 ranger VLSI, Conexant, Skyworks and Old Models 2 01-19-2002 07:05
Page generated in 0.58260 seconds with 9 queries
