08-31-2008, 00:15 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | ::>>tgl Mpeg4 Sim Insert 100% Okkkkkk<<:: MODEL NO-N 400 ==== log: [8/30/2008 4:19:09 PM] ==== COM12 [Serial3] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1641:69B8 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: CKT26_05C_PCB01_GPRS_MT6226_S01.A810I_ST_5_01B_ENG LISH.BIN ver. sw2: A810i_ST_5.01B_ENGLISH, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[CKT26_05C_PCB01_GPRS_MT6226_S01.A810I_ST_5_01B_ENG LISH.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT26_05C_PCB01_GPRS_MT6226_S01.A810I_ST_5_01B_ENG LISH.BIN]_20080830-162333.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 267 sec Remove/Install battery now ! :::::::::::::::::::::::::::::::::::::::::::::::::: ==== log: [8/30/2008 4:37:16 PM] ==== COM12 [Serial3] selected Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono-CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1641:69B8 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: A810i_ST_5.01B_ENGLISH Version: PCB1.1 detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... done 60 byte(s) read verification... verification done: 35044801123456 Finished, time used: 46 sec Remove/Install battery now ! :::::::::::::::::::::::::::::::::::::::::::::::::: ::: ==== log: [8/30/2008 4:38:12 PM] ==== COM12 [Serial3] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1641:69B8 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: CKT26_05C_PCB01_GPRS_MT6226_S01.A810I_ST_5_01B_ENG LISH.BIN ver. sw2: A810i_ST_5.01B_ENGLISH, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done Finished, time used: 37 sec Remove/Install battery now ! ==== log: [8/30/2008 4:51:47 PM] ==== COM12 [Serial3] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1641:69B8 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: A810i_ST_5.01B_ENGLISH Version: PCB1.1 detecting structure #2... done 60 byte(s) read imei: 35044801123456 connection Ok detecting structure #5 (mode-1)... 0 1 done 204 byte(s) read writing data... verification... verification Ok Finished, time used: 53 sec Remove/Install battery now ! TURAN |
The Following User Says Thank You to TUR@N ALAM For This Useful Post: |
11-12-2008, 12:24 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @turan alom Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
1202 1203 insert sim solu..................100% | jodhpur_raj | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 04-30-2013 08:04 |
1202 insert sim solution 100% by pictures | >>PakFones<< | Nokia Hardware & Hardware Repair | 24 | 05-16-2011 07:03 |
1202 insert sim solution 100% by pictures | sipra1234 | Nokia Hardware & Hardware Repair | 5 | 03-02-2010 20:35 |
C902 after insert test sim insert correct usim | ayubalikhan | SETool2 | 3 | 08-08-2008 08:22 |
X427 unlocked wrong card with one SIM and other SIM work 100% | tajona | Trident/AGERE Platform | 0 | 05-09-2005 02:32 |
