07-15-2015, 04:43 | #1 (permalink) | ||
No Life Poster Join Date: Sep 2005
Member: 183976 Status: Offline Thanks Meter: 134 | Thanks infinity and a Question ... Quote:
07-15-2015, 19:55 | #3 (permalink) |
Member: 183976 Status: Offline Thanks Meter: 134 | here is the log [QUOTEStart at : [15/07/2015 / 03:26:16] Operation : Format FileSystem [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005400AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007B , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable!][/QUOTE] |
