11-22-2018, 14:26 | #1 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2806504 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | Is there a solution to my problem My dongle stops giving me a mistake smart-card misconfiguration contact === DongleManager [Infinity] v1.70 [11/22/2018 14:27:58] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000081EB18154082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 1C9C81EB Firmware version: 0137.02 === Process started: 11/22/2018 14:28:00 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
11-22-2018, 19:38 | #2 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
11-22-2018, 19:57 | #3 (permalink) |
Member: 2806504 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | I did not use crack I'm why I use crack and I have a dongle ?? I did not know that the crack program stopped the dongle Is there a solution to my problem ?? |
11-22-2018, 20:41 | #5 (permalink) |
Member: 2806504 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | Yes the software was used olly debugger To explain on YouTube On the seriousness of malware on a dongle I did not know that the dongle depended on the olly debugger The team should put an alert on this program So that others do not fall into this same mistake I had no bad intention on the side of the dongle I have a video explaining why I use it on youtube |
11-22-2018, 22:24 | #6 (permalink) | |
11-23-2018, 18:08 | #9 (permalink) |
Member: 2806504 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | I told you I did not correct the program I was explaining the dongle on my YouTube channel I wanted to warn of the debug Believe me unwittingly Stop the dongle This is all I hope so |
11-23-2018, 18:10 | #10 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | You should read the agreement text from installer, already here,, debug, crack, sniffer and other stuff are forbbiden, and can damage Your Dongle, Next time play with debug away From Infinity Software, its clear now? |
The Following User Says Thank You to yuranc8 For This Useful Post: |
11-26-2018, 00:06 | #13 (permalink) | |
Do not tell us about youtube but you must explian why do you use olly debugger with Infinity software. waiting | |
11-28-2018, 12:08 | #14 (permalink) |
Member: 2806504 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | I use google translator only I told you I did not use the crack with the dongle Maybe a line has not been used with the dongle I do not know In my device there is no crack |
