Old 01-29-2008, 07:38   #1 (permalink)
Registered User
Member: 100376
Sonork: 100.1591842
Thanks Meter: 150
spice s600 success fully repaired by flashing with infinity & flash file at sopport s
i have success fully repaired restar problem of s600.intially it was showing bad flash ic i reflow it and erase the flash with option of format whole flash chip and then flashed with one of the flash file from support site now the phone is working fine here is the log
COM4 [VCP0] selected
Device: Spice S600
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
Connecting, wait...
Initializing[6217:8A00]...
CPU: MT6217
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98001B00000009:FFFFFF00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
slowest
Set baud Done
Identification...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Area: Firmware
Write: Firmware
formatting...
flash: 98001B00000009:9AD8D300000000
Write Done
Finished, time used: 2575 sec
Remove/Install battery now !
Old 01-29-2008, 20:37   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Thank you very much for detailed test report !
Old 11-02-2011, 16:22   #3 (permalink)
Arzzu's Avatar
Member: 1611261
Sonork: 1677675
Thanks Meter: 62
Question Spice s600 dead
COM3 [VCP0] selected
module v3.62
Device: Spice-S600
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6217:8A00]...
CPU: MT6217
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98004900000002:29EA0000000000
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 00880000/00780000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Spice-S600__ffs...
file saved: C:\Documents and Settings\Pappu\Desktop\Spice-S600__ffs_20111102-204331.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
flash: 98004900000002:9AD8D300000000
Finalization Done
Finished, time used: 14 min 23 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
File is reapeared but phone does not on
Help me Thanks in Advance..........................................
POST HERE success fully repair "SUPER DONGLE" dharmeshslnk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-04-2010 06:22
KE 970 LG shine successful flash with infinity! kmaxmax Infinity-Box 11 11-11-2009 19:58
is the flAshing for t749 fully safe by ust, ay one hav flashed?? peter002 UST Pro II 1 09-28-2009 05:08
<< Success Fully Repaired ThomSon Th102 >> Faisal_Computer Infinity-Box 7 11-17-2007 20:26
Page generated in 0.16963 seconds with 9 queries
