Old 03-03-2011, 16:30   #1 (permalink)
Member: 715429
Thanks Meter: 258
Tinno Tv990 o T521 UNlock ok but phone is LockED
Action: "sp-unlock"
unlock method: smart fast
Model: Tinno-TV900
Checking data, wait...
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: T521.PR.R1.0.V008.VE
Version: TINNO35_09A_HW
New firmware found (v.3.78, database date: 03.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
83 byte(s) read
imei: 35333604075897
connection Ok
189 byte(s) read
reading data...
building new data...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 21 sec
Remove/Install battery now !
Action: read unlock codes
unlock method: read codes
Model: Tinno-TV900
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
83 byte(s) read
connection Ok
189 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
177 byte(s) read
reading data...
972 byte(s) read
lock[1] code: - 12345678
lock[2] code: - default
lock[3] code: - 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: - default
lock[7] code: - default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 20 sec
FW is MovilneT Venezuela
Old 03-03-2011, 16:58   #2 (permalink)
Member: 715429
Thanks Meter: 258
Here Full flash
TINNO35_09A_PCB01_GPRS_MT6235B_S01.T521_PR_R1_0_V0 08_VE__firmware_20110303-104445.B4M.bin - 4shared.com - online file sharing and storage - download
readinG Full Flash ,,, please add to support
Device: Autodetect 6228-6253 NAND
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: T521.PR.R1.0.V008.VE
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_T521_PR_R1_0_V 008_VE.bin
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: unexpected answer:
startup code area #1 is valid
startup code area #1 detection done
rom info ver: 07
sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.T521_PR_R1_0_V0 08_VE.BIN
project-id: T521.PR.R1.0.V008.VE, D688ED06
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
area size: 32Mb
number of areas/bytes to read: 1:02000000
file saved: C:\Documents and Settings\Administrador\Escritorio\TINNO35_09A_PCB0 1_GPRS_MT6235B_S01.T521_PR_R1_0_V008_VE__firmware_ 20110303-104445.B4M.bin
Disconnect...
done
file saved: c:\InfinityBox\ChineseMiracle\backup_security\TINN O35_09A_PCB01_GPRS_MT6235B_S01.T521_PR_R1_0_V008_V E__system_log_20110303-105257.B4X.bin
Finished, time used: 21 min 3 sec
Old 03-04-2011, 23:08   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
If you talk about TV990 - flash phone with this file from support area: Tinno-TV990_TINNO30_08A_GEMINI_PCB03_GPRS_MT6230_S02.TV9 90_08A_W0832_TINNO_V065_2010-08-10_En_Es_unlock.B4M.bin
If you talk about TV900 - flash phone with this file from support area: inno-TV900_TINNO35_09A_PCB01_GPRS_MT6235B_S01.T521_PR_R 1_0_V008_VE_2010-10-27_En_Es_Movilnet_Venezuela_unlock.B4M.bin
What is the results ?
Old 03-04-2011, 23:11   #4 (permalink)
Member: 130995
Tell me, what phone you talk about ?
TV900 ?
T521 ?
TV990 ?
In thread name you write TV990 and T521...
In software you have selected Model: Tinno-TV900
Flash read from T521...
What model we talk about ??????
And what is T521 ? What is brand name ?
Old 03-05-2011, 17:55   #5 (permalink)
resident2011's Avatar
Member: 1530237
Sonork: 100.1614868
Thanks Meter: 5,598
I have 2 different models
Tinno T521
Tinno Tv990
I have these 2 models. subi why the fw of Tinno T521 to analyze and add the Unlock
When flashing the flash Tinno tv990 to support the result is dead
Old 03-06-2011, 16:49   #6 (permalink)
Member: 130995
If your phone is TV990 - flash phone with this file from support area: Tinno-TV990_TINNO30_08A_GEMINI_PCB03_GPRS_MT6230_S02.TV9 90_08A_W0832_TINNO_V065_2010-08-10_En_Es_unlock.B4M.bin
If your phone is TV900 - flash phone with this file from support area: inno-TV900_TINNO35_09A_PCB01_GPRS_MT6235B_S01.T521_PR_R 1_0_V008_VE_2010-10-27_En_Es_Movilnet_Venezuela_unlock.B4M.bin
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-26-1999 06:22
Page generated in 0.21796 seconds with 9 queries
