12-17-2010, 14:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: pccomp Age: 42
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURK EY_05_13 DEAD after flash edited with LangEditor. after write back to phone - phone not turn on. write original backup. again not turn on. Security area damaged. why ? Infinity not backup it ? always buck up Code: ==== [12/17/2010 4:54:03 PM] ==== COM2 selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 10 sec Remove/Install battery now ! Code: Device: Autodetect 6228-6253 NAND ==== [12/17/2010 4:54:43 PM] ==== COM2 selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E580.MP.F1.Turkey.05.13 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_TURKEY_05_13.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN project-id: E580.MP.F1.Turkey.05.13, 30989C17 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.25, database date: 24.10.2010): TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: E:\TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13__firmware_20101217-170323.B4M.bin Disconnect... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13__system_log_20101217-170517.B4X.bin Finished, time used: 10 min 34 sec Remove/Install battery now ! Code: smart-card: connected Loading file v.03... editor_corrected_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13__firmware_20101217-170323.B4M.bin.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN project-id: E580.MP.F1.Turkey.05.13, 30989C17 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-08-07 14-06 hw1: TINNO35_09A_HW hw2: 09A_TINNO35_09A ==== [12/17/2010 5:16:52 PM] ==== COM2 selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13__firmware_20101217-170323.B4M.bin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E580.MP.F1.Turkey.05.13 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_TURKEY_05_13.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN project-id: E580.MP.F1.Turkey.05.13, 30989C17 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.25, database date: 24.10.2010): TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830 Unknown firmware found (v.3.25, database date: 24.10.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13__system_log_20101217-172353.B4X.bin Finished, time used: 7 min 1 sec Remove/Install battery now ! Code: ==== [12/17/2010 5:26:23 PM] ==== COM2 selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 10 sec Remove/Install battery now ! Device: Autodetect 6228-6253 NAND Flash phone with firmware from support area ! Code: COM2 selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13__firmware_20101217-170323.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_TURKEY_05_13.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E580.MP.F1.Turkey.05.13 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_TURKEY_05_13.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN project-id: E580.MP.F1.Turkey.05.13, 30989C17 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_TURKEY_05_13.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN_179C9830 Unknown firmware found (v.3.25, database date: 24.10.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 6 min 44 sec Remove/Install battery now ! Code: ==== [12/17/2010 5:39:40 PM] ==== COM2 selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E580.MP.F1.Turkey.05.13 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580_MP_F1_TURKEY_05_13.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_TURKEY_05_13.BIN project-id: E580.MP.F1.Turkey.05.13, 30989C17 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done Disconnect... done Finished, time used: 29 sec Remove/Install battery now ! |
12-31-2010, 10:25 | #10 (permalink) |
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | download here friends. http://rapidshare.com/files/44008422...K_EY_05_13.rar (dont forget, this is NAND firmware) |
The Following 3 Users Say Thank You to *Diablo* For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
