Old 04-08-2017, 11:21   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question Xiaomi Redmi Hongmi Note 3 USER CODE RESET ???
Hi, I want to reset user code on Xiaomi Redmi Hongmi Note 3 Xiaomi Redmi Note 3 (MediaTek) - Full phone specifications
Mediatek MT6795 Helio X10 cipset
It has bootloader loked so VOLUME DOWN + POWER combination doesn't work (it enters directly on FASTBOOT mode)
Found on other place a complicate tutorila to flash the phone, but I want a easy solution to reset this phone with Infinity.
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Reconnect Power/Cable!
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Old 04-08-2017, 11:50   #2 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
another thing: after searching found that there are 2 version of this phone: Mediatek and Snapdragon , I thik that I have the second one: Xiaomi Redmi Note 3 - Full phone specifications can this be reseted with Infinity????
Card found : xxxxxxxx , v0135
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09
Operation : Identify [ v1.09 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device not found!
Check cable, connection and drivers!
Wait for phone...
Device not found!
Old 04-08-2017, 12:45   #3 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Infinity platform detector dosen't recognize the phone:
Connect device to USB cable while holding BOTH volume buttons!
Connected device :
Details : 0x2717 : 0x904D
Vendor : No vendor info [NOT IN BASE]
Mode : No mode info [NOT IN BASE]
any sugestions of how to reset it?????
Old 04-08-2017, 13:46   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Need to connect phone in EDL mode, sometimes need to use edl cable or test point even.
Br.
Infinity Box Team.
Old 04-09-2017, 07:42   #5 (permalink)
Member: 2082450
Thanks Meter: 1,454
There it make no sense to try MTK locked phones in qlm module.....
Either need to flash it or wait for the update...
Old 05-02-2017, 21:20   #6 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Infinity Box Team.
I can't connect this phone even with EDL CABLE. What is the corect procedure?...any one managed to reset this phone?
Page generated in 0.20146 seconds with 8 queries
