Old 09-05-2016, 16:58   #1 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
tool dl image fail when trying to repair Imei
Lenovo s650
Old 09-05-2016, 17:24   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Make Fix DL and check result after.
Old 09-05-2016, 17:34   #3 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
Fix DL fix then phone but the problem is imei
when i try repair imei its bering the same problem
Old 09-05-2016, 18:08   #4 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
IMEI repair Result
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004B375530304D089F1A7403B0BB
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00U7
[eMMC] : FLASH_CID : 1501004B375530304D089F1A7403B0BB
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xBFC92F2A3AAAF95076C639AC4FF2C39C
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 8626350********
Set IMEI [01] : 8626350********
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 10 ]
Sync...
Device boot not done
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just re-insert cable) on this step
Reconnect Power/Cable!
Fix Dl Mode Result
Operation : Fix DL Errors [ v1.55 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
DA DLFix Passed!
Done!
Elapsed: 00:00:30
But When i try repair imei the Tool Dm Image faild again
i alredy try to reinstall windows and drivers
Old 09-05-2016, 18:31   #5 (permalink)
Cheater -Don't Deal with him-
Member: 1707492
Thanks Meter: 606
hi bro use nv file writ it hop pov slove give me model im try to give you nv file or others free tools have reper your phone imei
Old 09-05-2016, 18:32   #6 (permalink)
JayDi's Avatar
Member: 462970
Did you checked imei inside of phone after operation?
Does BaseBand is Ok?
Old 09-05-2016, 19:04   #7 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
my Phone info
Operation : Check / Read Info [ v1.55 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Lenovo
ProdName : S650_ROW
ProdModel : Lenovo S650
Device : S650_ROW
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : S650_ROW_S308_150121
MODEM :
BaseBand : MT6582_S00_S650_ROW_V109_1_wg_n
Done!
Elapsed: 00:00:09
Old 09-05-2016, 19:16   #8 (permalink)
JayDi's Avatar
Member: 462970
In Phone/Settings/About - there is exists BaseBand version info?
Old 09-05-2016, 19:52   #9 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
BaseBand version is ok
Old 09-05-2016, 20:13   #10 (permalink)
JayDi's Avatar
Member: 462970
What IMEI's phone show now , when you enter *#06# ?
What CM2 say in log on "Identify" with all settings enabled?
Old 09-05-2016, 20:20   #11 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : Lenovo
ProdName : S650_ROW
Device : S650_ROW
AndroidVer: 4.4.2
MTKxCPU : MT6582
MODEM :
Done!
Elapsed: 00:00:08
Old 09-05-2016, 20:40   #12 (permalink)
JayDi's Avatar
Member: 462970
NVM inside is dead.
Write this one first :
https://www.4shared.com/file/J5LxP5F...ROW_V109_.html
Old 09-05-2016, 20:57   #13 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
Boss i write this file Phone software damage
then i flash again and imei is ok now
thank you and love you allot CM2 Team
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : Lenovo
ProdName : S650_ROW
Device : S650_ROW
AndroidVer: 4.4.2
MTKxCPU : MT6582
SECURITY :
IMEI_SW [1] : 8639810********
IMEI_SW [2] : 8639810********
BTMAC Addr : CC07E423C2D2
WiFi MAC : CC07E423C2D2
MODEM :
Done!
Elapsed: 00:00:12
The Following User Says Thank You to obaid_457 For This Useful Post:
Old 09-06-2016, 05:13   #14 (permalink)
JayDi's Avatar
Member: 462970
Was enough just make factory reset. Keep that in mind next time.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.21693 seconds with 8 queries
