05-04-2009, 03:12 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Touchscreen calibration ALL POSIBLE MDDE NOT HELP PHONE BEFORE ARE GOOD ONLY FFS FORMAT CPU: MT6223 high speed boot On chip: 0011:C964:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: MAUI.07A.W07.36.35 Version: HEXING23_07A_HW detecting structure #2... 0 done 44 byte(s) read imei: 35009273399844 connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! WHATS IS THIS ERROR .... bR... |
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post: |
05-04-2009, 03:24 | #3 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | as i said try all mode but same...calibration before 100% good now not why what is this bug or not..... even full format then put good imei same problem..... |
05-04-2009, 06:55 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | try to cilibrate with low version of china miracle may solved |
The Following User Says Thank You to shahabuddin For This Useful Post: |
05-04-2009, 07:16 | #7 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | IMEI CHANGE: CPU: MT6223 high speed boot On chip: 0011:C964:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: MAUI.07A.W07.36.35 Version: HEXING23_07A_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 0 done 44 byte(s) read verification... verification done: 00000000000000 Finished, time used: 23 sec Remove/Install battery now ! CALIBRATION: CPU: MT6223 high speed boot On chip: 0011:C964:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: MAUI.07A.W07.36.35 Version: HEXING23_07A_HW detecting structure #2... 0 done 44 byte(s) read imei: 00000000000000 connection Ok detecting structure #5 (mode-2)... 1 2 3 4 6 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! |
Bypass damaged Touchscreen calibration solution... | InfinitySupport | Infinity-Box | 223 | 10-28-2010 16:51 |
how to skip touchscreen calibration in c2000 | sayedhas | SpiderMan | 5 | 08-10-2008 03:54 |
Touchscreen calibration OK by MODE-2 | Chandreshswami | Infinity-Box | 4 | 08-02-2008 10:19 |
n82 I can not work Touchscreen Calibration | ahmedasmet | Infinity-Box | 4 | 06-25-2008 07:11 |
Bypass damaged Touchscreen calibration solution ( ChineseMiracle v2.45) | Ja\/\/aD | Service Products News & Updates | 0 | 05-25-2008 12:47 |
