07-30-2009, 12:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Touchscreen calibration failed COM8 [VCP0] selected module v2.87 Action: touchscreen calibration mode: 1 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001303:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: EPE888A.0.1.0.1T16M0407_EPTC Version: E888_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35410120096691 connection Ok detecting structure #5 (mode-1)... 18 17 16 15 14 11 10 8 7 6 5 4 1 0error: detection failed (14 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! COM8 [VCP0] selected module v2.87 Action: touchscreen calibration mode: 2 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001303:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: EPE888A.0.1.0.1T16M0407_EPTC Version: E888_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35410120096691 connection Ok detecting structure #5 (mode-2)... 18 17 15 13 12warning: wrong packet cs 11warning: wrong packet cs 10 8 7 5 3 2warning: wrong packet cs 1warning: wrong packet cs 0error: detection failed (14 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 8 sec Remove/Install battery now ! COM8 [VCP0] selected module v2.87 Action: touchscreen calibration mode: 3 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001303:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: EPE888A.0.1.0.1T16M0407_EPTC Version: E888_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35410120096691 connection Ok detecting structure #5 (mode-3)... 18 17 16 13 12 10 8 7 6 3 2 0error: detection failed (12 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 7 sec Remove/Install battery now ! ChineseMiracle_v2.45 COM8 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A05]... CPU: MT6225 high speed boot enabled chip: 0001303:0003 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: EPE888A.0.1.0.1T16M0407_EPTC Version: E888_GEMINI_HW detecting structure #2... 5 11 18 24error: detection failed (4 tries), read flash and send to support connection Ok detecting structure #5... 0 3 4 7error: detection failed (4 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! i try with reverse, but same problem i try with 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed but same problem. infinity team, this is a big bug, please remove or repair this problem. BR Last edited by IkaMazini; 07-30-2009 at 12:46. |
07-30-2009, 12:55 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | try and try to change mode 1/2/3 until you success, i encounter same but success almost 3x in different mode. br |
07-31-2009, 07:43 | #4 (permalink) | |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Quote:
before post, read all my topic! same result. | |
07-31-2009, 09:50 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | How to calibrate touchscreen: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. make full flash backup for emergency case 8. go to software "Service" page 9. select calibration "mode-1" 10. make "Reverse calibration order" un-checked 11. press "Calibrate touchscrren" button and follow instruction given by software 12. if software can not make calibration with "detection failed" error: - select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one) - repeat calibration process - test phone after each "mode" try 13. if calibration process finished without errors but touchscreen can not work well: - DO NOT change calibration "mode" ! - make "Reverse calibration order" option checked - repeat calibration process again - test phone 14. if still no luck with calibration after all tries: - make full flash backup for emergency case - make "format ffs" - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
08-01-2009, 07:17 | #7 (permalink) | |
this is a joke? after my post? ok, big thanks for help. please close ... | |
08-06-2009, 23:24 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Touchscreen calibration procedure changed, ChineseMiracle v2.88 released: http://forum.gsmhosting.com/vbb/showthread.php?t=801258 Please, try to calibrate phone with new software, waiting for your results. |
s3 touchscreen calibration failed... | gsmsikar | Infinity-Box | 6 | 08-07-2009 07:59 |
Ztc N328 touchscreen calibration failed | KK Mobile | Infinity-Box | 1 | 05-06-2009 20:20 |
<<< China A666 Touchscreen Calibration Failed >>> | khadim100 | Infinity-Box | 2 | 04-05-2009 11:36 |
Touchscreen calibration failed in N99i | lie_james | Infinity-Box | 1 | 01-23-2009 19:40 |
subject: touchscreen calibration failed : New firmware detected (2.70) | Faisal_Computer | Infinity-Box | 1 | 12-06-2008 13:57 |
