08-16-2009, 12:16 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: raigarh india Age: 51
Member: 108186 Status: Offline Thanks Meter: 241 | touchscreen calibration problem |
08-16-2009, 12:31 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | brother you download latest module chinese 2.89 and first you read full flash and save full flash file. then you press button of repair pen calibration, software asked you give me full flash file then you give the file and your problem solved. |
08-16-2009, 20:45 | #3 (permalink) | |
Make "format ffs" Power-on phone Power-off phone repair imei make "calibration" procedure. Phone should be alive. If calibration parameters will be lost after some time it may be that phone has hardware fault, f.e. flash chip is partially damaged or bad soldered or other hardware damage. | |
Bypass damaged Touchscreen calibration solution... | InfinitySupport | Infinity-Box | 223 | 10-28-2010 16:51 |
Touchscreen calibration Problem......... | guru4gsm | Infinity-Box | 2 | 08-23-2009 23:25 |
Touchscreen calibration OK by MODE-2 | Chandreshswami | Infinity-Box | 4 | 08-02-2008 10:19 |
n82 I can not work Touchscreen Calibration | ahmedasmet | Infinity-Box | 4 | 06-25-2008 07:11 |
Bypass damaged Touchscreen calibration solution ( ChineseMiracle v2.45) | Ja\/\/aD | Service Products News & Updates | 0 | 05-25-2008 12:47 |
