08-11-2009, 06:35 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Searchig.....
Member: 573543 Status: Offline Sonork: 100.1602019 Thanks Meter: 97 | T99 flashing problem sigmatel T99 it was the problem file manger dsnt open then i the formatt(compleate mode)the phone but no luck.after i backup the phone. and am trying to write new file J26_PCB01_GPRS_MT6226_S01.SW_V00_02_AOLIFENG__sigm atel-s90i_16m_En_Ru_El_Fr_Es_Id_Vn_Tr_Farsi_Pt_Ar.B0M but showing error msg.after i tryed writing original file its showing same error msg flash[J26_PCB01_GPRS_MT6226_S01.EDL_08A_V03.BIN]_20090809-014649.B0M__J26_PCB01_GPRS_MT6226_S01.EDL_08A_V03. BIN__16m_En_Ru_El_Fr_Es_Id_Vn_Tr_Farsi_Pt_Ar un checked advanced chip detecting but no luck thnx |
08-11-2009, 13:30 | #2 (permalink) |
Freak Poster Join Date: Sep 2007 Location: KERALA,INDIA Age: 38
Member: 597241 Status: Offline Sonork: 100.1575009 Thanks Meter: 85 | i think ur used wrong file pls try this methode read file from a working set then write that file into ur phone that may be help |
08-11-2009, 13:35 | #3 (permalink) |
Member: 597241 Status: Offline Sonork: 100.1575009 Thanks Meter: 85 | i think u flashed with wrong file do this read full flash file from a working handset and try to write that file into ur phone thatwill help u |
08-16-2009, 06:33 | #8 (permalink) | |
Member: 573543 Status: Offline Sonork: 100.1602019 Thanks Meter: 97 | Quote:
hi i tried the latest version but not done COM3 [VCP0] selected module v2.89 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash "smart write" active write: Firmware flash[J26_PCB01_GPRS_MT6226_S01.EDL_08A_V03.BIN]_20090809-014649.B0M__J26_PCB01_GPRS_MT6226_S01.EDL_08A_V03. BIN__16m_En_ Ru_El_Fr_Es_Id_Vn_Tr_Farsi_Pt_Ar.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F09C:9458 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #02 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #03 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................... .................................................. .................................................. .................... ................ warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: D:\Program Files\InfinityBox\ChineseMiracle\_ffs_20090816-104651.B0E.bin flash: 98000300000001:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................... .................................................. .................................................. .................... ................ warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished ffs address can not be detected, value from database assigned: 00E00000/00200000 detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent detecting psn code area... psn code area is absent Area: Firmware flash: 98000300000001:FFFFFF00000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 555 sec Remove/Install battery now ! | |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
sigmatel t99 strange problem after flash | drjaved_akhter | Infinity-Box | 4 | 10-13-2009 21:40 |
sigmatel t99 software problem | ayaz_hasham | Chinese Models & Cloned Phones | 5 | 10-25-2008 21:47 |
sigmatel t99 software problem | ayaz_hasham | Chinese Models & Cloned Phones | 0 | 10-18-2008 10:37 |
Sigmatel T99 flashing Problem.... | amol_sm | Infinity-Box | 4 | 09-27-2008 22:17 |
