Old 08-23-2009, 10:55   #1 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Question Touchscreen calibration Problem.........
Touchscreen calibration problem with CM 2.89 I'm trying to calibrate touch screen of Dual sim Dual imeiModel Name TOP-1 MODEL-0003 JGTEL corporation but always have this error
Here is the log............
COM4 [VCP0] selected
module v2.89
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
KCM25_GEMINI_PCB01_GPRS_MT6225_S00.FS_F909_JG_MULT LAN_A_O1_V2__fullflash_20090823-114857.B0M.bin loaded
detected record size adjusted
error: unknown ffs structure
error: can't detect eeprom structure
error: operation failed !
Finished, time used: 8 sec
Remove/Install battery now !
And firmware is also missing in support Area.
Any Ideas from experts..........
Old 08-23-2009, 14:07   #2 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Use old version of Chiese Miracle
Click My Blog
Old 08-24-2009, 00:25   #3 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
send this fimrware to [email protected]
Bypass damaged Touchscreen calibration solution... InfinitySupport Infinity-Box 223 10-28-2010 17:51
touchscreen calibration problem deepaksawdia Infinity-Box 2 08-16-2009 21:45
Touchscreen calibration OK by MODE-2 Chandreshswami Infinity-Box 4 08-02-2008 11:19
n82 I can not work Touchscreen Calibration ahmedasmet Infinity-Box 4 06-25-2008 08:11
Bypass damaged Touchscreen calibration solution ( ChineseMiracle v2.45) Ja\/\/aD Service Products News & Updates 0 05-25-2008 13:47
Page generated in 0.25458 seconds with 8 queries
