09-12-2009, 14:48 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: gorontalo
Member: 629228 Status: Offline Thanks Meter: 17 | touchscreen calibration successful k-touch a650 how, connect to the box without the LCD, then follow the calibration procedure using infinity These logs used lcd ==== log: [9/12/2009 6:34:39 PM] ==== COM3 [VCP0] selected module v2.91 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... TYM072142_500_PCB01_GPRS_MT6226_S01.072142_500_V07 50__fullflash_20090825-101404.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:E417:2394 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 26 sec Remove/Install battery now ! and it is not used lcd ==== log: [9/12/2009 6:35:33 PM] ==== COM3 [VCP0] selected module v2.91 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... TYM072142_500_PCB01_GPRS_MT6226_S01.072142_500_V07 50__fullflash_20090825-101404.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:E417:2394 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 072142_500_V0750 Version: TIANYU26_06A_HW 42 byte(s) read imei: 35879000017433 connection Ok 512 byte(s) read 147 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! may be useful for others br, grahaponsel, gorontalo |
The Following User Says Thank You to naurah For This Useful Post: |
Bypass damaged Touchscreen calibration solution... | InfinitySupport | Infinity-Box | 223 | 10-28-2010 16:51 |
post touch screen calibration successfully With CPF_BOX | kabirhossain | CPF-BOX Ⅱ | 2 | 01-23-2010 07:35 |
K - Touch A650 Multimedia Phone with Touch Screen | IPMART | ipmart WebShop | 0 | 03-17-2009 13:20 |
K-Touch A650 need flash file... | lianfeng | Infinity-Box | 7 | 02-20-2008 20:38 |
K-touch A650 Pinout Problem | Nasmi | Infinity-Box | 5 | 12-11-2007 14:32 |
