04-14-2007, 09:02 | #1 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | Tracfone C139 Problem Quote:
04-14-2007, 16:46 | #5 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: rajabrothers communications Age: 43
Member: 155773 Status: Offline Sonork: 1606514 Thanks Meter: 87 | Quote:
2nd time use search botton first before post http://forum.gsmhosting.com/vbb/showthread.php?t=334357 br raja | |
04-14-2007, 17:44 | #6 (permalink) | |
http://forum.gsmhosting.com/vbb/showthread.php?t=309557 http://forum.gsmhosting.com/vbb/showthread.php?t=290589 http://forum.gsmhosting.com/vbb/showthread.php?t=271431 Please, read instruction in yellow window (you will see it for sure when you start software). Unlock/Flash C139: 8.8.17 http://forum.gsmhosting.com/vbb/showthread.php?t=334357 @rajabrotherscom Thank you ! | |
05-05-2007, 10:15 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what tutorial? this is very easy. 3 ways to do this: 1. old software versions: just do needed procedures 2. new software version: cut test point- and then do needed procedures 3. newest PCB which is hiding test point under CPU- remove CPU with hot air, reball CPU, do not set ball to leg NI, solder CPU back and make all operation like it is with cutted track So, if you cant connect with phone in normal way- cut track, if you cant find this track according picture- this means it is new PCB and you need to remove ball. thats it |
05-06-2007, 20:54 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | C139 hardware difference hello! here is a picture of 2 different hardware configuration of motorola C139: as you can see on right image track which is marked by RED colur goes stright under CPU. This is new type PCB, where cutting test point will not help. You need to desolder CPU and remove ball "N1" marked by BLUE colur. Left image is old PCB, you can detect it be red track which makes "Z" before hide under CPU. This is a old type. To get communication with it you need to cut test point (marked by X) |
05-06-2007, 21:57 | #14 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | Quote:
many many thx realy great work wbr | |
05-07-2007, 02:49 | #15 (permalink) |
Member: 42604 Status: Offline Thanks Meter: 187 | ok here's the recap to make it as straight and simple as possible... Here's what to look to know if it is the old PCB..if the tracks look like this..just cut the FOIL mark with RED X..then you can connect.. For new PCB like this...you need to removed CPU, then removed ball N1 and put the CPU back.. Hope this helps.. BTW Infinity Team..I lost my keypad function and got insert SIM doing this modification..but I can still power my phone.. Regards... |
Moto Tracfone C139 sw version 9.2.17 | rontekgsm | Infinity-Box | 24 | 12-23-2008 07:12 |
W175g tracfone , flashing problem | etimoult | Scout | 1 | 10-13-2008 07:20 |
C139 Tracfone unlock problem | rajumobile | Smart-Clip | 3 | 11-07-2007 22:29 |
please help with unlocking menu for tracfone c139 | latincell | Motorola ODM | 4 | 09-01-2007 09:52 |
c115 c139 problem | REALTHOMAS | Infinity-Box | 6 | 10-30-2006 23:30 |
