11-15-2016, 21:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 16
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | TRADENO SONY C3 high-copy SC8830 I HAVE TRIED 4 BOOT MODES WITH SC8830 CPU NOT WORK PHONE IS ON BUT WITH VIRUS Code: Start at : [15/11/2016 / 21:09:04] Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [15/11/2016 / 21:09:11] Start at : [15/11/2016 / 21:09:21] Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [15/11/2016 / 21:09:31] Start at : [15/11/2016 / 21:10:08] Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [15/11/2016 / 21:10:30] Start at : [15/11/2016 / 21:11:05] Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [15/11/2016 / 21:11:43] Start at : [15/11/2016 / 21:12:28] Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [15/11/2016 / 21:12:35] Start at : [15/11/2016 / 21:13:11] Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable |
