06-19-2008, 03:33 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | trend 101 died after flash show phone lock there fore i tried to flash it. i down load its frimware file from support when i try to flash the phone the erasing frimware operation hang and stop,now the phone is died every time i am trying to flash the erasing frimware operatin hang indiffrent fields i am using pinfinder for interface,also i try slow flashing this is the log of the phone in infenity Pana01 software COM5 [VCP0] selected Device: Trend-T101 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware error: write failed[00400000] Write Failed Finished, Remove/Install battery now ! Time used: 53 sec |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
06-19-2008, 06:08 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | witch type of mobile locked ? and when you are trying to flash 1st time is you battery full ? cause i am tried many time to flash i got no any error and yes one thing more always use slow speed for that model for success Br Faisal_Computer |
06-19-2008, 08:34 | #3 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Karachi, Pakistan Age: 52
Member: 50106 Status: Offline Sonork: 100.109487 Thanks Meter: 224 | Quote:
Wait New Update Thanks | |
06-19-2008, 10:15 | #4 (permalink) |
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | I am using pinfinder pinfinder has own + and - it doesnt need battry |
11-14-2008, 10:21 | #9 (permalink) |
No Life Poster Join Date: May 2008 Location: "I work for Good weekend"
Member: 765990 Status: Offline Sonork: 100.1582347 Thanks Meter: 207 | i have got the same problem with full battry also the same COM1 [Serial0] selected module v1.53 Device: Trend-T101 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-sta_20081114-021844.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-sec_20081114-021847.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-complete_20081114-021854.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, Remove/Install battery now ! Time used: 36 sec what should i do know. always stop here. i have downloded the flash from support please help?????????? when i load eprrom always stop here at 12 % COM1 [Serial0] selected module v1.53 Device: Trend-T101 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-sta_20081114-022151.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-sec_20081114-022154.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-complete_20081114-022201.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom repair write error [007F2000:0800]... error: write failed[007F0000] Write Failed Finished, Remove/Install battery now ! Time used: 37 sec please help urgent. |
02-21-2009, 17:48 | #11 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | |
<<< Trend T-101 dead after flash >>> | khadim100 | Infinity-Box | 34 | 08-15-2011 07:28 |
trend 101 dead after flash | usman0000 | Infinity-Box | 1 | 01-21-2010 22:54 |
please add new lg kp108 -- need full flash phone is died after flash with kp107 | residentdenuevo | VygisToolbox | 3 | 12-10-2009 18:59 |
t39m died after flash | Halas | Sony Ericsson | 2 | 09-08-2003 09:07 |
My phone ME45 died after flashing.Help! | DupleX | x1x to x45/x50 | 1 | 04-20-2002 23:07 |
