Trend T100 Flashing Problem 1 Attachment(s) hi my Trend T100 is dead only service lights blink when press on/off switch i try to flash set with infinty but facing this error |
Download latest software from support area. Make "advanced chip detection" box checked ("Settings" page) and repeat flashing process. |
1 Attachment(s) Quote:
post here text log, not screenshot. See operation process log here: D:\Program Files\InfinityBox\ChineseMiracle\operation.log |
here is opration log ==== log opened: [9/28/2007 10:45:47 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.54 S/N: 2C42:010C Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... Trend-T100_1x8pin_MAUI[1].05B.W06.08.T100.V2.0.D_HEDY05_05B_HW_2007-01-17_8m_En_Cn_Hi_Cn_Ar.B0M.bin loaded COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:00000000000000 flash: Amd PL064J D 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd PL064J D 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd PL064J D 8Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd PL064J D 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detecting eeprom area in 1 chip(s)... flash: 01227E22022201:FFFFFF00000000 checking area[00000000]: 00000000-007FFFFF... eeprom found near: 00700000 detecting eeprom size... eeprom size: 00100000 eeprom chip: 00 eeprom area: 00000000:00700000-007FFFFF reading [eeprom]... file saved: backup_eeprom_20070928-104919.B0E.bin flash: 01227E22022201:FFFFFF00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished Area: Firmware flash: 01227E22022201:FFFFFF00000000 Write: Firmware error: error# 000001E4 error: flash write error: 00010000:00002000 Write Fail Finished, time used: 59 sec Remove/Install battery now ! please check and guide me i will be thank ful to infinit team |
You must follow my advices but NOT IGNORE it ! Download latest software from support area. Make "advanced chip detection" box checked ("Settings" page) and repeat flashing process. |
what you mean by new software ? i am using the latest module of chines miracle ver 1.54 and there is only two flash files for trend i down load both and try to flash set one by one and i also "Advance Chip Detection Method" check and if not then did it unchecked but every time i am facing error (sorry i am new user of infinity but i know you will not fell it and continue to help because i think infinty team is best team of any other team) i am posting again recent log please guide me if not solve then i have to return back to customer ------------------------------ Loading file v.02... Trend-T100_repair_eeprom_02[1].B0E.bin loaded COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:00000000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detecting eeprom area in 1 chip(s)... flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom found near: 00700000 detecting eeprom size... eeprom size: 00100000 eeprom chip: 00 eeprom area: 00000000:00700000-007FFFFF reading [eeprom]... file saved: backup_eeprom_20070928-233406.B0E.bin flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished Area: Firmware flash: 01227E22022201:18E59F00000000 Write: Firmware error: error# 000096E4 error: flash write error: 00010000:00002000 Write Fail Finished, time used: 82 sec Remove/Install battery now ! |
hello! i think it worth to re-solder flash IC. some data/address lines lost contact |
i have tren t100 only service light on. i flash it .... flash ok but sam ............................ ......................pzl help me............................... infiniti team |
Here is step-by-step instruction that I prepared especially for you: http:///vbb/showthread.php?t=447277 Please, read it carefully. |
