Old 09-27-2007, 18:32   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 547
Trend T100 Flashing Problem
hi
my Trend T100 is dead only service lights blink when press on/off switch
i try to flash set with infinty but facing this error
Old 09-28-2007, 01:06   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,220
Download latest software from support area.
Make "advanced chip detection" box checked ("Settings" page) and repeat flashing process.
Old 09-28-2007, 07:05   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 547
sir i did as you said but error is same
Old 09-28-2007, 09:12   #4 (permalink)
Member: 130995
post here text log, not screenshot.
See operation process log here: D:\Program Files\InfinityBox\ChineseMiracle\operation.log
Old 09-28-2007, 12:30   #5 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 547
here is opration log
==== log opened: [9/28/2007 10:45:47 AM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v1.54
S/N: 2C42:010C
Wait...
Device: Autodetect 6205-6227 NOR
Done
Loading file v.02...
Trend-T100_1x8pin_MAUI[1].05B.W06.08.T100.V2.0.D_HEDY05_05B_HW_2007-01-17_8m_En_Cn_Hi_Cn_Ar.B0M.bin loaded
COM9 [VCP0] selected
Checking data, wait...
advanced flash detection disabled
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6205:8B00]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22022201:00000000000000
flash: Amd PL064J D 8Mb
detecting chip #01 in region #00...
flash: 01227E22022201:FFFFFF00000000
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 00800000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-007FFFFF...
eeprom found near: 00700000
detecting eeprom size...
eeprom size: 00100000
eeprom chip: 00
eeprom area: 00000000:00700000-007FFFFF
reading [eeprom]...
file saved: backup_eeprom_20070928-104919.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
detect device identification, method #1...
detection phase #1...
detection phase #2...
warning: identification information not found, possible reasons:
.old firmware type w/o identification data
.damaged firmware
.damaged hardware
detect device parameters finished
Area: Firmware
Write: Firmware
error: error# 000001E4
error: flash write error: 00010000:00002000
Write Fail
Finished, time used: 59 sec
Remove/Install battery now !
please check and guide me i will be thank ful to infinit team
Old 09-28-2007, 15:14   #6 (permalink)
Member: 130995
S/N: 2C42:010C
Wait...
Done
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
What to do:
eeprom chip: 00
reading [eeprom]...
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
Write Fail
read text in log window...
You must follow my advices but NOT IGNORE it !
Old 09-28-2007, 20:12   #7 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 547
what you mean by new software ?
i am using the latest module of chines miracle ver 1.54
and there is only two flash files for trend i down load both and try to flash set one by one and i also "Advance Chip Detection Method" check and if not then did it unchecked but every time i am facing error (sorry i am new user of infinity but i know you will not fell it and continue to help because i think infinty team is best team of any other team) i am posting again recent log please guide me if not solve then i have to return back to customer
Trend-T100_repair_eeprom_02[1].B0E.bin loaded
advanced flash detection active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
flash: 01227E22022201:18E59F00000000
Initialize Done
Set baud...
921600
Set baud Done
Identification...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
eeprom chip: 00
reading [eeprom]...
file saved: backup_eeprom_20070928-233406.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
error: error# 000096E4
Write Fail
Finished, time used: 82 sec
Old 09-28-2007, 21:00   #8 (permalink)
Member: 148515
Thanks Meter: 14,629
hello!
i think it worth to re-solder flash IC.
some data/address lines lost contact
Old 10-12-2007, 18:23   #9 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 537
i have tren t100 only service light on.
i flash it .... flash ok but sam ............................
......................pzl help me............................... infiniti team
Old 10-12-2007, 19:20   #10 (permalink)
Member: 130995
Here is step-by-step instruction that I prepared especially for you: http:///vbb/showthread.php?t=447277
Please, read it carefully.
Make trend t100 flash files from this backup mr quiet Chinese Cocktail 5 11-01-2009 13:37
trend T100 flashing erer paklink Infinity-Box 15 08-06-2007 10:10
T100 flash problem kieron555 VLSI, Conexant, Skyworks and Old Models 5 03-11-2004 23:18
T100 Flashing, Problems!! gsmdeli VLSI, Conexant, Skyworks and Old Models 7 02-15-2003 02:27
** T100 flash problem ** bluelights VLSI, Conexant, Skyworks and Old Models 0 10-13-2002 02:19
Page generated in 0.41819 seconds with 9 queries
