12-07-2007, 01:12 | #6 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 58
Member: 81104 Status: Offline Thanks Meter: 25 | COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6219:8A01]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: chip layout not detected error: autodetection failed Finished, time used: 66 sec Remove/Install battery now ! i hv another ok phone how i backup from it? i try as normal method but now my fone nothing todisplay |
12-07-2007, 13:26 | #9 (permalink) |
Member: 81104 Status: Offline Thanks Meter: 25 | dear InfinitySupport Product Supporter Join Date: Mar 2005 Location: www.infinity-box.com Posts: 9,831 Member: 130995 Status: Offline First (main) CPU has flash chip 16Mb Second CPU has flash chip 4Mb InfinitySupport i read flash file from another phone but my phone not revive its show wrong address as log shown last post |
12-08-2007, 01:45 | #11 (permalink) |
Member: 81104 Status: Offline Thanks Meter: 25 | dear i backup from another fone after flash my dead fone its work like make call butt nothing on screen only vertically color lines thanks reply may i send flash file backup to u |
12-08-2007, 19:12 | #12 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Infinity-Box "Chinese Miracle": How to repair "White LCD", "Black LCD", "no LCD" problems: 1. check phone hardware: LCD unit may be damaged. 2. check phone hardware: LCD flex cable may be damaged. 3. use other flash files for flashing, because exist many different phones with different LCD hardware types so need to use different firmware files and find firmware that work good for your LCD hardware. Select flash file with similar firmware version, phone model name is not important, only firmware version is important. | |
01-07-2008, 22:39 | #13 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | Atten!!!!!!!!! Please Plz tell me about nor flashing and nand flashing i hv trend t500 i flashed it by another working phone backup flash file now my phone powerup and making calls but shows on lcd vertical line although its shows bettery point and singnal but color line on all lcd before flashing fone ok but not shows 2nd sim signal and not end 2nd sim call after backup flash it work ok but lcd fake color remember my working fone and fulity fone have same fireware virsion Plz help me what i do ????/// |
trend t500 flash files needed | astana2007 | Infinity-Box | 3 | 05-22-2008 09:20 |
needed trend t500 flash files | usman0000 | Chinese Cocktail | 3 | 01-08-2008 14:21 |
trend t500 flash files | usman0000 | Infinity-Box | 0 | 01-07-2008 23:55 |
trend t500 flash files | usman0000 | Chinese Cocktail | 1 | 12-23-2007 12:08 |
