09-30-2016, 23:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Chinese Miracle II [MTK module] v 1.56 Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.56 ] Operation : Read Pattern/DP Lock [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:01:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
10-01-2016, 00:13 | #3 (permalink) |
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Card found : S/N : xxxx, v0132 Chinese Miracle II [MTK module] v 1.56 Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642029B028472443FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0xEB54ECB9AB82D6941175FFD7E61A6283 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029B028472443FF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642029B028472443FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0xEB54ECB9AB82D6941175FFD7E61A6283 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
