02-28-2007, 23:18 | #1 (permalink) |
Banned Join Date: Dec 2003 Location: Miami USA Age: 47
Member: 45477 Status: Offline Thanks Meter: 22 | Trying to unlock c261 tracfone Other than bad cable, what else can it be? There is no indication the the software sees the phone. Do I need to cut track? Any advice? |
03-01-2007, 03:32 | #4 (permalink) | |
No Life Poster Join Date: Oct 2005 Age: 43
Member: 186632 Status: Offline Thanks Meter: 51 | Quote:
Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LPA7_0166 Flex ver: FLEX_90_64_5009 cpu id: 08B6 imei eeprom: 01091100599044 SW ver: 0.1.66 sp-locked: 302720302370 Check Flash-1 Done Check Flash-2... reading ... file saved: Backup_eeprom_calibration_01091100599044_2007-2-28_13-33-51.34E.bin Err: this unit can't be unlocked, error#1 Check Flash-2 Fail Finished, time used: 35 sec Remove/Install battery now ! How can I solve this prolem ? | |
03-01-2007, 13:05 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @alru111 use "USB serial port" that you see after you connect box to PC. no need to re-install, uninstall etc. just see what is COM port for this "USB serial port" and use it. |
03-01-2007, 16:56 | #11 (permalink) | |
c139: http://forum.gsmhosting.com/vbb/showthread.php?t=334357 c261: need to double check cable | |
03-01-2007, 19:20 | #13 (permalink) | |
Freak Poster Join Date: May 2004 Age: 59
Member: 64405 Status: Offline Thanks Meter: 12 | Quote:
if phone can't be detected by software it can be cable problem or problem with phone connector and check Fbus interface conect properly. BR saleem | |
03-01-2007, 21:07 | #14 (permalink) | |
problem to unlock c261 tracfone!!! | samirr | Smart-Clip | 16 | 09-16-2008 23:12 |
How to Convert C261 tracfone - read here. | edong | Scout | 5 | 02-08-2008 06:56 |
How to Convert C261 tracfone - read here. | edong | Scout | 2 | 01-24-2008 19:00 |
Unlock C261 Tracfone | erickxson | Infinity-Box | 27 | 04-18-2007 09:30 |
C261 After trying to unlock now Blinking screen | kasamiko | Infinity-Box | 1 | 12-29-2006 12:13 |
