Old 07-01-2008, 04:23   #1 (permalink)
torpedo_seluler's Avatar
Member: 368629
Thanks Meter: 87
Beyon B555 Maybe got some bugs
I tried to flash Few Unit of Beyond B555 mostly succeed but some got problem Erasing error in flash address 00400000. Then i assemblyng the phone and see the Flash Chip are SST Brand. Three unit are same brand and failed. But the other brand Flash Chip manufactor Flashed success.
Here is the Log:
COM24 [VCP1] selected
Device: Beyond-B555
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 00BF:7353
Connecting Done
Check hardware...
sw version: ULC2GL 0 A 0 q
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sta_20080701-101127.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sec_20080701-101259.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20080701-101311.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: Firmware
error: erase failed: 00400000
Write Failed
Finished, Remove/Install battery now !
Time used: 190 sec
Old 07-07-2008, 11:46   #2 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Me too have same problem :
COM3 [VCP0] selected
Device: Beyond-B555
Action: flash write
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 00BF:7353
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
file saved: E:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sta_20080707-173815.B1E.bin
loading data...
data loaded
file saved: E:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sec_20080707-173818.B1E.bin
file saved: E:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20080707-173825.B1E.bin
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Firmware >>>> stuck at 42%
need solution from Infinity Team ....
thanks
Today i got new bug module not open.... sahil2000ind MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 11-15-2009 15:56
hi sir i got some sets when i try to format i got flash erase error unlock_solution Infinity-Box 4 09-21-2009 12:05
NEW samsung software got next BUG !! G600 flashing not work, D880 too wgmmmx HWK 1 06-10-2008 22:43
~~~ Check here , u maybe got u need ~~~ .::Gsmdenis::. Main Sales Section 0 01-18-2007 19:32
7110 motors, anyone got some spare?! logosunlimited Main Sales Section 2 05-04-2002 05:55
Page generated in 0.15614 seconds with 9 queries
