06-15-2008, 05:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | TV Mobile H688 fail read fullflash & details COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 34 sec Remove/Install battery now ! Read NAND as below COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 error: bootcode load error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elease Power button now ! Boot Fail Finished, time used: 16 sec Remove/Install battery now ! |
06-15-2008, 10:41 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | this is mcu 2 (MCU_b) with which you try work, if you use pinfinder- just skip mcu 2 pin (uncheck pin number in advanced settings) and search again for pinout. next pinout found will be pinout for MCU_a continue to work with this pinout and all will be ok thanks Last edited by InfinityHelp; 06-15-2008 at 11:40. |
06-16-2008, 04:46 | #3 (permalink) |
Member: 117956 Status: Offline Thanks Meter: 115 | @mentari Thanks for fast reply , i using pinfinder . Can you please show me picture (uncheck pin number in advanced settings) which changing pinout for MCU_a & MCU_b . Thanks in advance ! |
06-16-2008, 08:57 | #4 (permalink) |
Member: 39948 Status: Offline Thanks Meter: 68 | f.e. if you found rx 3 and tx 4 then you just need to un check 3 and 4 both coloum. so pin finder will skip find for this pin. Thanks. |
The Following 3 Users Say Thank You to mentari For This Useful Post: |
thin tv mobile k300 cam & tv prob | habibkhalil | Infinity-Box | 3 | 02-09-2010 20:28 |
pinout fot tv mobile h688 | shsampath | Chinese Models & Cloned Phones | 0 | 01-23-2009 07:10 |
tv mobile phone h688 | nihana | Infinity-Box | 1 | 10-25-2008 20:47 |
TV mobile H688 pin out | acelai00 | Infinity-Box | 5 | 05-05-2008 08:04 |
How to read fullflash? | MOBICOM | UFS2 + UFS3-Tornadoflasher | 1 | 08-29-2004 01:55 |
