Old 02-20-2008, 16:39   #1 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Sonork: 100.1600687
Thanks Meter: 174
TV900 frist sim formated done but freeze after try to format sconed sim
here my log
COM7 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:C7C1:8C66
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.19F4A327.[GHOST_PCB01_GPRS_MT6226_S01.ENVISION_EV7810_C_TC_V 2_4_B02_M.BIN_BE8EBDC6].rpl
New firmware detected:
- make "Repair security area" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 19F4A327
identification#1 protocol ver: 04
ver. sw1: GHOST_PCB01_GPRS_MT6226_S01.ENVISION_EV7810_C_TC_V 2_4_B02_M.BIN
ver. sw2: ENVISION_EV7810_C_TC_V2_4_B02_M, 39427141
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _19F4A327_GHOST_PCB01_GPRS_MT6226_S01.ENVISION_EV7 810_C_TC_V2_4_B02_M.BIN_BE8EBDC6_20080219-153517.B0X.bin
Finished, time used: 272 sec
Remove/Install battery now !
and
Action: reset
Boot...
19200
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
boot step size: 0400
Boot Done
Initialize...
flash: BF7353FFFF0052:18E59F00000000
warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error
flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
460800
Set baud Done
Identification...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard eeprom/ffs offset assigned: 00700000
checking area[00000000]: 00000000-007FFFFF...
eeprom/ffs found near: 003E0000
Detected eeprom/ffs address is non-standard: 003E0000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[003E0000] confirmed by user
eeprom/ffs size: 00420000
ffs chip: 00
eeprom/ffs area: 00000000:003E0000-007FFFFF
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
error: error# 0000FF3B
error: flash erase error: 003E0000
Write Fail
Finished, time used: 54 sec
please help......
Old 02-20-2008, 21:14   #2 (permalink)
Member: 148515
Thanks Meter: 15,722
hello!
faulty flash ID: flash: BF7353FFFF0052:18E59F00000000
this is not real flash ID. this means you must re-solder second CPU flash.
or if you dont have skills for that at least try to heat it.
then repeat procedure
Old 02-21-2008, 07:21   #3 (permalink)
Member: 281857
Sonork: 100.1600687
Thanks Meter: 174
i re-solded . but same problem maybe this flash damage.thanks for support
Old 02-21-2008, 11:27   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,402
@habeebo
try to use latest ChineseMiracle v2.29, it was some improvemenst regarding flash types. I am not sure that this may helps but anyway please try it.
After try to UnLock KU970 with Micro-Box Phone now not work with Orignal Sim As Well ZoHaiB_(FoneGSM) Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 6 11-05-2009 12:56
hi sir i got some sets when i try to format i got flash erase error unlock_solution Infinity-Box 4 09-21-2009 13:05
when i use 5800 cable to unlocl it works but when i try to flash it it dosnt work why observer123 Universalbox 2 07-25-2009 17:48
A727 freeze after try to unlock chris2007 UST Pro II 8 05-28-2009 21:58
NEC 344i unlock done but han gs when inserted non-accepted sim? kungpaoski Infinity-Box 2 03-19-2009 00:32
Page generated in 0.55813 seconds with 8 queries
