08-29-2009, 02:49 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Sadly pinfinder new, its dead. Its sadly Im bought infinity box and happy. All working fine no problem whit that, Nice box, good software, I check about chinese miracle and the pinfinder and decide buy my pinfinder. im receive it and check cables and box, then after read manual, connect pinfinder and activate and make some tests (User code, read flash, format ffs, unlock) tried to make imei repair from phone ZTE x760. For that its needed that phone are fully powered but pinfinder cant power it. Im make two or four tries phone can be detected and fails to write imei. Then phone cant be detected cant power on. Then restart software and surprise software cant detect pinfinder. Im checked 8-8 pins cable and dissasemble box and make replace (short diode) but nothing. Power led of pinfinder its on (green). But box cant detect it. Now Next step?? Warranty?? Any other trick?? Thanks for reply. |
08-29-2009, 18:04 | #3 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | None i tried making installation on clean pc but same result, cant be detected. Some times when press detect button and fast conect pinfinder show this error. searching adapter at COM6... too many retries can't find adapter searching adapter at COM6... too many retries can't find adapter warning: 2nd answer absent warning: 2nd answer absent too many retries done |
08-29-2009, 18:21 | #5 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 144091 Status: Offline Thanks Meter: 73 | also check in device manager if pinfinder is properly installed and what comport it is. is it really in Com6? my pinfinder work well and lots of chinaphones had been successfully repaired...that should be a tough box! |
08-29-2009, 18:23 | #6 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | Check logs Code: Log First time Please, read more details about PinFinder: www.infinity-box.com or www.infinity-box.biz ==== log opened: [28/08/2009 17:40:39] ==== Application: C:\Archivos de programa\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.19 Smart-Card S/N: XXXX Smart-Card firmware version: 0112 Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Loading configuration... Initializing cable list... Initializing platforms... Initialization finished searching adapter at COM35... adapter found, version: 2000 S/N: XXXXXXXXXXXXXXXXXXXXXXXXXXXX done Initializing... done Log after ==== log opened: [28/08/2009 19:11:40] ==== Application: C:\Archivos de programa\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.19 Smart-Card S/N: XXXX Smart-Card firmware version: 0112 Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Loading configuration... Initializing cable list... Initializing platforms... Initialization finished searching adapter at COM35... too many retries can't find adapter searching adapter at COM35... too many retries can't find adapter too many retries done searching adapter at COM35... too many retries can't find adapter searching adapter at COM35... too many retries can't find adapter too many retries done searching adapter at COM35... too many retries can't find adapter searching adapter at COM35... too many retries can't find adapter too many retries done Log infinity ==== log: [28/08/2009 18:30:41] ==== COM35 [VCP0] selected module v2.85 Device: ZTE-X760 Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4803:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.8F230328.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106.BI N_40182282].rpl rom info detection finished device-id: 8F230328 rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106.BIN ver. sw 2: X760_Z11_S_A07A106, 7DDDE7BF ffs offset/size: 00E00000/00200000 ffs address assigned: 00E00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106__fullflash_part_1_of_1... file saved: C:\Archivos de programa\InfinityBox\MModule\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106__fullflash_part_1_of_1 _20090828-184138.B0X.bin file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106__syste m_log_8F230328_40182282_20090828-184841.B0X.bin Finished, time used: 1077 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, XXXX set to default value ! Make flash backup before this procedure ! Do you want to continue ? operation aborted WARNING ! Settings will be cleared, user data erased, XXXX set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [28/08/2009 18:49:02] ==== COM35 [VCP0] selected module v2.85 Action: reset settings Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4803:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z11_S_A07A106 Version: ZTEMT25_07A_HW_A 44 byte(s) read XXXX: 35235302962895 connection Ok building list... done items to clear: 163 warning: wrong packet cs items cleared: 163 of 163 building list... done items remains: 0 Finished, time used: 38 sec Remove/Install battery now ! ==== log: [28/08/2009 18:54:21] ==== COM35 [VCP0] selected module v2.85 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4803:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z11_S_A07A106 Version: ZTEMT25_07A_HW_A 44 byte(s) read XXXX: 13579024681122 warning: current phone XXXX is incorrect ! It's need to repair XXXX for correct phone functionality ! connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 52 sec Remove/Install battery now ! Action: XXXX Model: ZTE-X760 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: ZTEMT25_07A_HW_A Software version: X760_Z11_S_A07A106" Software date: 2006.06.14 Barcode: MT012345678901234567 XXXX write method: mode-1 XXXX write channel: XXXX #1 for dual sim/mono CPU new XXXX: 352353029628952 verification failed operation failed ! Finished, time used: 94 sec Power off phone now ! XXXX 35235302962895 already was repaired: 28/08/2009-18:59:20 Continue with this XXXX ? Action: XXXX Model: ZTE-X760 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 82 sec Power off phone now ! XXXX 35235302962895 already was repaired: 28/08/2009-19:01:39 Continue with this XXXX ? Action: XXXX Model: ZTE-X760 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 82 sec Power off phone now ! XXXX 35235302962895 already was repaired: 28/08/2009-19:06:46 Continue with this XXXX ? Action: XXXX Model: ZTE-X760 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 84 sec Power off phone now ! XXXX 35235302962895 already was repaired: 28/08/2009-19:08:14 Continue with this XXXX ? Action: XXXX Model: ZTE-X760 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 79 sec Power off phone now ! XXXX 35235302962895 already was repaired: 28/08/2009-19:09:46 Continue with this XXXX ? Action: XXXX Model: ZTE-X760 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 460800 error: connection failed ! operation failed ! HERE i press stop Finished, time used: 22 sec Power off phone now Pinfinder dead after that |
08-29-2009, 21:09 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! to get phone powered On from pinfinder power you must activate Silent mode on it. Some chinese models require startup current 0,5-1A just for playing melody. Of course USB port can not provide this. regarding your current problem: does your main infinity box is still working? i mean without pinfinder you can still work with it? |
07-29-2010, 09:14 | #11 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Negros, Philippines
Member: 525940 Status: Offline Thanks Meter: 213 | if it is new then return to reseller for replacement. just remember if gadgets have warranty you must return it to reseller for replacement |
try to flash 6230 now its dead | benie | UFS2 + UFS3-Tornadoflasher | 11 | 02-23-2005 11:59 |
6310i v5.22 ...now its dead ....helppppp :( | claudio_gsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 26 | 07-03-2003 17:05 |
a hot tip to save ur phone b4 its dead | fawzi | x1x to x45/x50 | 2 | 09-21-2002 23:19 |
I Unlocked A T28sc, now its dead! Pls help! | Dj King | Old Ericsson Phones & Sony Phones | 12 | 05-18-2002 02:48 |
M35 unlock now its dead, help! | NUGSM | x1x to x45/x50 | 1 | 10-03-2001 11:50 |
