UCOO ZTC 8191 Flash File Required for Infinity Box Sir I required flash file of ztc 8191 ucoo MTK6226 Urgently Please Help me. thanks |
What is required firmware version ? |
NOR Flash model :[SPANSION] S71PL129N NOR flash size :01000000 (16.0 M) NOR flash id code :0001227E (22212200)[95] |
hello! please post here log of "read detailed information" operation |
module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:583D:09E1 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... warning: wrong cs at 0x0025F6E4, retry... error: too many retries during read operation startup code area #1 is damaged, recalculation required rom info detection finished device-id: 305CCEE8 rom info protocol ver: 04 ver. sw 1: QVGA_PCB01_GPRS_MT6226_S01.P08_SC_SAM_NB0_1_2_3NTC 2_26B.BIN ver. sw 2: P08_SC_SAM_NB0_1.2.3NTC2_26B, 642274BA ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 error: wrong answer: E6 error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user Finished, time used: 52 sec Remove/Install battery now ! |
hello! i dont like this log. what is phone problem? is it dead? |
Thanks |
hello! have you tried to solve problem by formating? make full bakcup before this |
THANKS |
hello! unfortunately, we dont have exact same flash file in our collection. however you can try similar one: flashfiles/ChineseMiracle/_MT6226/QVGA_PCB01_GPRS_MT6226_S01.P10_SC_ITL_NBO_CSTAR_V1 _2_NTB1_R1C1_26B_20070714_16m_En_Ru_Fr_Th_Vn_Ar.B0 M.bin just make full backup before using it, so you would be able to restore phone back in emergency case |
