Old 03-14-2009, 22:27   #1 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
<<< Trend T-101 dead after flash >>>
hello infinity team, i got trend t101 in on condition , some times mobile in autorestart condition, i decide to flash the phone , i download firmware from support site & flash the phone while flashing a error message appear (see in log) . now mobile is dead , any help please.
COM4 [VCP0] selected
module v1.64
Device: Trend-T101
Checking data, wait...
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00BF:7353
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
error: erase failed: 00400000
Write Failed
Finished, time used: 23 sec
Remove/Install battery now !
The Following User Says Thank You to khadim100 For This Useful Post:
Old 03-15-2009, 08:07   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
is battery was full when you trying to flash ?
Please try to flash again with fully charged battery if no luck then rehot it and try again and post results
Faisal_Computer
Old 03-15-2009, 08:13   #3 (permalink)
gsm_'s Avatar
Member: 991620
Thanks Meter: 429
read Other Set Full Flash
Write 100000000000000% ok
The Following User Says Thank You to gsm_ For This Useful Post:
Old 03-16-2009, 18:12   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@khadim100
select model BSNL-G200 and flash phone again.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-16-2009, 19:10   #5 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
Originally Posted by InfinitySupport View Post
@khadim100
i flash with BSNL-G200 firmware. but same error,
please anyone upload trend t101 full flash .
Old 03-16-2009, 19:18   #6 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
Faisal_Computer
thanks for reply sir, i flash this phone via infinity pinfinder (useing pinfinder power not use mobile bettary)
Old 03-16-2009, 21:25   #7 (permalink)
Member: 130995
what is "same" ?
p.s.
in future any thread with problem description like "the same", "still same", "same problem", "not work" etc. will be closed due to we can not help if we do not see any problem explanation
Old 05-30-2009, 08:38   #8 (permalink)
Member: 235616
Thanks Meter: 67
100000% Tested
Old 06-01-2009, 22:32   #9 (permalink)
Member: 130995
Hello,
What is "same error" exactly ?
Old 06-10-2009, 16:49   #10 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
@InfinitySupport
I encountered the same problem while flashing Trend T101 with files from support site. Same error occured "error: erase failed: 00400000" Then I made search on the forum and come to this thread.
I selected model "BSNL-G200" from the list and used T101 files from the support site. All the process goes very well (no more error: erase failed: 00400000) but phone couldn't be turned ON. Then I used this file from support "Digibee-BSNL-G200CF_Jan-16-2008.B1M" and flashed the phone and the result is fully working phone.
Thank you very very much for this wonderful tip.
Now one question arise here why this error occur while selcted model is T101 and why flashfiles of T101 from support site are not working????
Best Regards!
yawarniazi
The Following 3 Users Say Thank You to yawarniazi For This Useful Post:
Old 01-26-2010, 06:16   #11 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
@Infinity
After flash these flash file i have got a dead phone.
Trend-T101_ULC2_Apr-18-2008.B1M
Trend-T101_2007-Nov-12.B1M
But i make search on google then i reach on this thread
I follow instruction that write yawarniazi.
I flash this file "Digibee-BSNL-G200CF_Jan-16-2008.B1M"
now phone is alive and i has change IMEI of this phone.
==== log: [1/26/2010 10:02:58 AM] ====
COM23 [VCP0] selected
module v1.72
Device: Digibee-BSNL-G200CF
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL Z c 0 A d 0 q
Check hardware Done
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100126-100312.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100126-100313.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100126-100314.B1E.bin
Check memory ...
unlocking...
lock found
lock type #1 found
operation done
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 125 sec
==== log: [1/26/2010 10:05:45 AM] ====
module v1.72
Action: "repair imei"
new imei: 354401005889664
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL N W 0 A X 0 q
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100126-100559.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100126-100559.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100126-100600.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_imei-area_20100126-100604.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20100126-100607.B1E.bin
Check memory ...
lock found
lock type #1 found
imei found #2
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Erasing: lock-area
Writing: lock-area
Erasing: eeprom-security
Writing: eeprom-security
Write Done
Finished, time used: 33 sec
Finished
The Following 3 Users Say Thank You to Shakeel_pattoki For This Useful Post:
Old 05-11-2010, 21:24   #12 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Any body can upload fullflash file for trend t101 also eeprom plz..........
Old 05-12-2010, 20:50   #13 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Infinity team help plz i cant boot fone after flash with available firmware on support area but agin can boot with backup but ieme damage like(000496250000) and also no sim massege after backup ?????????
Old 05-13-2010, 18:34   #14 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
infinity team help me plz..............
Old 05-14-2010, 22:17   #15 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Infinity team need ur help plzzzzzzzzzzzzzzzzzzzz
<<< SAM C160 NO SERVICE AFTER FLASH - Final Solution >>> khadim100 UST Pro II 42 09-09-2011 06:04
trend 101 dead after flash usman0000 Infinity-Box 1 01-21-2010 22:54
trend 101 died after flash Maiwand khan Infinity-Box 13 08-22-2009 12:09
<<< w610i dead after unlock >>> khadim100 SETool2 8 08-19-2009 09:48
Page generated in 0.32937 seconds with 9 queries
