ufone t156 new unlock failed => module version: v. => operation (3) started: COM1 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037844670 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 21 sec Power Off/On phone now unlock done but still lock using pana 1.72 v2 br yasermalik |
hello, this is under Test , that why Thanks for sharing your test report but its better if you post in http://forum.gsmhosting.com/vbb/showthread.php?t=874885 BR Faisal_Computer |
this is not successfull test report its a problem and i think infinty cnt make the unlocking for these type of phone because it was a counter blocked fone and for reset the counter have to flash like with eeprom and there is no option for writing anything |
First methode need! Quote:
