Old 12-16-2018, 19:58   #1 (permalink)
aymandh4's Avatar
Member: 2529545
Sonork: aymandh4
Thanks Meter: 68
hi pls fix this problem spd sc9832 android 8.1
after select flash 8.1 cm2spd user fd1 and fd2 from flash ok but no read info no rest frp no read firmware ...........
[IMG][/IMG]
Start at : [16/12/2018 / 11:46:12]
Operation : Read FullFlash [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 98 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 98 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Error Init FL mode!
Read failed! Error_Info : zram init error! Send report and model identify to support!
Reconnect Power/Cable!
Finish at : [16/12/2018 / 11:48:24]
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 7.x]
Loading : EVERCOSS_M55_V03_8.1_16082018.pac
CRVersion : BP_R1.0.0
PacCPUinfo : sp9832e_1h10
PacVersion : MocorDroid8.1_Trunk
FastCheck : 0x0072968198
Loading files ...
File : fdl1-sign.bin
File : fdl2-sign.bin
File : sharkle_pubcp_customer_Smart_Phone_nvitem.bin
File : prodnv.img
File : u-boot-spl-16k-sign.bin
File : SC9600_sharkle_pubcp_customer_Smart_Phone_modem.da t
File : SharkLE_LTEA_DSP_evs_on.bin
File : SHARKLE2_DM_DSP.bin
File : sharkle_cm4.bin
File : PM_sharkle_cm4.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : u-boot-sign.bin
File : persist.img
File : sharkle_pubcp_customer_Smart_Phone_deltanv.bin
File : sml-sign.bin
File : vendor.img
File : tos-sign.bin
File : gnssbdmodem.bin
File : gnssmodem.bin
File : vbmeta-sign.img
File : sp9832e_1h10.xml
Load Ok!
Start at : [16/12/2018 / 11:50:57]
3. Insert cable
Phone found! [ 98 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Phone found! [ 98 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Finish at : [16/12/2018 / 11:53:14]
Start at : [16/12/2018 / 12:07:40]
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 98 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:23
Finish at : [16/12/2018 / 12:08:04]
Loading : GO1006_SS_SL_CWC_JM_V03_20180823_1545.pac
PacCPUinfo : sp9832e_xx
PacVersion : GO1006_SS_SL_CWC_JM_V03_20180823_1545_debug
FastCheck : 0x0054EC4DFB
Loading files ...
File : nvitem.bin
File : prodnv.img
File : SC9600_sharkle_pubcp_Smart_Phone_modem.dat
File : tos-sign.bin
File : sml-sign.bin
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : userdata.img
File : logo_uboot.bmp
File : logo_kernel.bmp
File : cache.img
File : vendor.img
File : logo_kernel3.bmp
File : logo_kernel4.bmp
File : logo_kernel5.bmp
File : customerdata.img
File : sc9832e.bin
File : sp9832e_xx_go.xml
Load Ok!
Start at : [16/12/2018 / 12:11:35]
3. Insert cable
Phone found! [ 98 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:26
The Following User Says Thank You to aymandh4 For This Useful Post:
Old 12-17-2018, 08:46   #2 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
try to select alternative loader from boot menu
The Following User Says Thank You to Arslanmayo For This Useful Post:
Old 11-22-2019, 14:55   #3 (permalink)
Member: 1567416
3. Insert cable
Phone found! [ 48 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Phone found! [ 48 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Old 11-22-2019, 16:40   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Use SP2 module instead SPD.
Page generated in 0.16007 seconds with 8 queries
