09-10-2008, 16:53 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: jb cell world Age: 47
Member: 70916 Status: Offline Thanks Meter: 56 | unable to calibrate touch screen |
09-11-2008, 07:24 | #5 (permalink) | |
Member: 70916 Status: Offline Thanks Meter: 56 | Quote:
COM3 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:C203:0006 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M310_M36L0T_Abroad_V2.0.2 Version: LONGYU25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2warning: wrong packet cs done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 15 sec Remove/Install battery now ! OM3 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:C203:0006 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M310_M36L0T_Abroad_V2.0.2 Version: LONGYU25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 11 sec Remove/Install battery now ! COM3 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:C203:0006 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M310_M36L0T_Abroad_V2.0.2 Version: LONGYU25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 1 2 3 done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! | |
09-11-2008, 07:26 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | FORMAT THE HANDSET IN SAFE MODE AND THEN DO calibrate OPPTION WITHOUT DISCONNETING PHONE WHEN AFTER POWER ON HANDSET PRESS CANCELL(RED KEY) TWICE AND CHEAK |
09-11-2008, 08:12 | #7 (permalink) |
Member: 70916 Status: Offline Thanks Meter: 56 | i have tried this to but after format with out disconnecting it is unable to calibrate but when connected by disconnecting after format it is showing calibration is done but no success |
09-11-2008, 13:21 | #9 (permalink) |
Member: 70916 Status: Offline Thanks Meter: 56 | if phone is inside menu then u can change the touch screen and check it with out that u cannot change touch screen and check in the start up which is showing calibration screen and i told before that it was working in my hand and i resetted it |
hi Mr. Please add formatted not calibrate touch-screen functionality to thank | 电源ic | SpiderMan | 2 | 01-04-2010 05:39 |
S4 Cant Calibrate Touch Screen ? | Chennairam | Infinity-Box | 7 | 03-09-2009 11:21 |
N82 CRAZY problem in calibration touch screen | MDK23 | Infinity-Box | 3 | 01-08-2009 02:43 |
N82 problem in calibration touch screen | MDK23 | Infinity-Box | 1 | 01-07-2009 21:43 |
i750 can't calibrate touch screen..... | aikonmani | Samsung Hardware Repair | 2 | 11-25-2008 17:45 |
