10-21-2016, 05:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | unable to connect |
10-21-2016, 05:38 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | http://forum.gsmhosting.com/vbb/f296...eport-2146494/ Note For Users :- Must Use Nokia Emergency Driver If U Use Qcom Dload Driver Phone Not Detect N Nothing Will Work... Do Not Do All Procedure In Same Connection If Not Reboot Auto Do It Manually (Means Need To Reconnect N Put In EDL For Each Separate Operation).... |
The Following User Says Thank You to Shani3 For This Useful Post: |
10-21-2016, 07:32 | #8 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | 1st Download & Install This dir=software/&uid=17094&file=InfinityBox_update_CM2QLM_Drivers_ v1.00.7z Then Go Tohttps://forum.gsmhosting.com/vbb/C:\InfinityBox\CM2QLM\Drivers Then Install All Exe Or Use Manual Driver For XP Folder To Install Manualy...Use Update Driver Option (Right Click On QHUSB) Select Update Driver Browse For Directory Ok Choose Nokia Emergency Driver It Will Work. |
The Following 2 Users Say Thank You to hitech care For This Useful Post: |
10-21-2016, 07:42 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Right click on current HS 9008 driver, navigate to C:\InfinityBox\CM2QLM\Drivers and install driver. Download driver from HERE. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
