09-08-2017, 07:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | unable to load factory file Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q383 Model Brand : Micromax Model Device: Q383 AndrVersion : 5.1 BaseBand CPU: SP7731GEA CompileDate : 20-May-16 3:15:16 AM Project Ver : MMX_Q383_SW_1.2.7_HW_2.0.0_20160520 Model Ext : Micromax Q383 ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!! Elapsed: 00:00:22 |
09-08-2017, 12:38 | #2 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Where is flashing error(log) Please provide flashing log/bad file error log for check... else try to flash with og flasher...... |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
09-08-2017, 14:32 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Are you talking about Mmx Q383? If yes, Team will check that error. Br. Infinity Box Team. | |
09-09-2017, 07:32 | #8 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | Yes before few days I also face same issue. Version Micromax_Q383_FOREIGN_V1.3.1 has charging issue so that i have to flash Micromax_Q383_FOREIGN_V1.2.9. Read Nv ok: Start at : [9/6/2017 / 8:00:10 PM] Operation : Read NV [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0xA596 Saved to : C:\Users\jyoti\Desktop\CX77xx_SPDNV.spdnv Elapsed: 00:04:14 Reconnect Power/Cable! Write H/W info: Start at : [9/6/2017 / 7:53:33 PM] Operation : HW Info OP [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! HWInfo structure present Write Operation Write done! Elapsed: 00:00:45 Reconnect Power/Cable! CM2 denied to flash as Bad file but og tool complete. Here is og tool linkhttps://www.sendspace.com/file/wb60q2 |
09-09-2017, 07:43 | #9 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ avtarkaint This model content HW Config file in its factory firmware so you cant flash it without factory flash toll . Br - srinibas |
The Following 2 Users Say Thank You to srinibas For This Useful Post: |
