11-20-2011, 10:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | unable to repair blink rd3530 here is the log ==== [11/20/2011 3:08:20 PM] ==== COM9 [VCP0] selected module v1.65 Device: LG-3530 operation: Repair "Blink" Phone should be Switched ON ! connecting... file selected: D:\InfinityBox\RD3530_SCR.bin QSC6010-RD3530 QSC6010-RD3530 LG RD3530 selected.. sending boot.. erasing... done.... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- done... Finished, time used: 2 min 26 sec with regards |
11-20-2011, 14:58 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
Not Always Blink Caused By Software Some Time Its Hardware Also Please Check Hardware Wbr <<<Megatron>>> | |
11-20-2011, 16:52 | #3 (permalink) | |
Product Supporter Join Date: Jun 2010
Member: 1319166 Status: Offline Thanks Meter: 1,476 | If Problem is with Hardware then you can't fix blink from software Quote:
Even if you flashed 100 times it will remain blink if it is caused from hardware software can't fix it .You can try factory flasher also result will be same . Just check Hardware Mostly caused due to bad LCD or Water damaged and charging connector . Regard's Infinity-CDMA | |
11-21-2011, 19:27 | #5 (permalink) | |
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Thanks for feedback Quote:
Hi, Thanks for feed back .Still i am confused you told in your first post that Code: sir i tried to repair lg rd3530 bur not got sucess. i flashed5 times after flash it still blink. Anyway you success to repair it via flashing that's good. We will try to add in future full flash so User can try full flash if they not success blink repair from efs blocks. Regard's Infinity-CDMA Last edited by Infinity-CDMA; 11-22-2011 at 14:01. | |
The Following User Says Thank You to Infinity-CDMA For This Useful Post: |
11-22-2011, 03:40 | #6 (permalink) |
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | its not false statement in 1st post, when i repaired it with infinity it still blink, even i tried 5 time at last i decided to flash 6th time it still blinked so i decided to return it to owner, and i unsold the cable from board and fitted the mobile and amazingly its working fine. that's the story behind. and i have not posted fake query for time waste. with regards |
11-22-2011, 05:24 | #7 (permalink) | |||
Answer You Have Given Already Quote:
Just Because Phone Was Not Getting Proper Power Supply From Box it Was Ur Fault You Didnt Checked With Battery Then How You can Blame On CDMA Tool? As In My First Post Already Mentioned Not Always Blink Caused Via Software And It Was Repaired in First Attempt But It Was Totally Ur Fault Quote:
So Now All Users Must Understand How Blink Caused It's Not Always Software Next Time Please Spend Some Time In Checking Where You Did Wrong Before Posting Wbr <<<Megatron>>> | |||
The Following User Says Thank You to <<<MEGATRON>>> For This Useful Post: |
11-22-2011, 13:59 | #8 (permalink) |
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Post made Sticky so user can see mistake they make . Dear User, I make this post sticky so that other user can see what common mistake they do while trying to repair blink. Some User always claim that software not work and bla bla . They can read this post and understand how easy to fix problem if it is software problem . Regard's Infinity-CDMA |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
