05-14-2011, 14:09 | #3 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1357163 Status: Offline Thanks Meter: 0 | Hello, sorry cause i use this post but i don't want to open another one about the ZTE... I have a ZTE G-N281 and i want to change the firmware. The reason is that i don't have the qwerty keyboard on this... I think if i change the firmware, this will fix the problem. The phone is new, has few months of use and i got it without the qwerty keyboard. I search on the web but i can't find the firmware files and the program with that i can change the firmware and i don't know how to do that. Mr. YellowBoss, can you help me? Please! Thank You! |
05-14-2011, 19:39 | #4 (permalink) | |
You can unlock/flash etc. this phone with Infinity-Box How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
TMobile T610 - Flashed GDFS, not completely unbranded though... | Phoebus | Sony Ericsson | 6 | 01-10-2004 12:14 |
Anyone has an unbranded stt-file | picotto | E-Gold Based Phones | 0 | 01-03-2004 10:36 |
Unbranding Nokia | Grunthos | Nokia Multimedia | 1 | 12-28-2003 19:25 |
Has Anyone Ever Tried 2 Update An Unbranded T610 With Emma2? | blueworld | Sony Ericsson | 10 | 12-01-2003 15:24 |
Has Anyone Ever Tried 2 Update An Unbranded T610 With Emma2? | blueworld | Old Ericsson Phones & Sony Phones | 0 | 10-15-2003 16:02 |
