09-20-2015, 12:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: india
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | Lava 402e format prob Code: Wait for phone... Phone found! [ 119 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done [31/0E] [AP] : Initial info read Ok! Done! Elapsed: 00:00:50 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 119 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
