Old 07-15-2008, 06:07   #1 (permalink)
Member: 229636
Thanks Meter: 48
Unhappy unknown chinaphone help
COM3 [VCP2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: imei
imei write method: mode-3
new imei: 350448011234561
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:83C1A96
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.39F6E3E3.[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_ L7EN_229_071130_LD0_0V0_SA75_CTF_BT.BIN_A52F6DB1].rpl
identification#1 detection finished
device-id: 39F6E3E3
identification#1 protocol ver: 04
ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_ L7EN_229_071130_LD0_0V0_SA75_CTF_BT.BIN
ver. sw2: SWAN+_6226_YTCQYR_L7EN_229_071130_LD0_0V0_SA75_CTF _BT, 4E92D05A
ffs offset/size: 00F00000/00100000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00F00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_ L7EN_229_071130_LD0_0V0_SA75_CTF_BT.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_ L7EN_229_071130_LD0_0V0_SA75_CTF_BT.BIN]_20080715-122643.B0E.bin
Backup required data Done
Patch required data...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei repair" procedure again
If imei can't be detected:
1. make "complete" ffs format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei repair" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_39F6E3 E3_CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQ YR_L7EN_229_071130_LD0_0V0_SA75_CTF_BT.BIN_A52F6DB 1_20080715-122743.B0X.bin
Finished, time used: 429 sec
Remove/Install battery now !
Old 07-15-2008, 09:34   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is the problem exactly ?
Did you tried to follow instruction given by software ?
Is instruction given by software not so clear ?
Old 07-24-2008, 01:52   #3 (permalink)
Member: 229636
Thanks Meter: 48
yes sir i follow all instruction and i will tried latest update and i will post the result...
Old 07-24-2008, 21:23   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
What is the problem exactly ? can you explane detailed?
Old 07-26-2008, 12:05   #5 (permalink)
Member: 229636
Thanks Meter: 48
Unhappy
fisrt sir customer say this is no power and i check and make full charge the battery unit ok but slave and standard imei starting in 135*****. change imei stardard ok already problem is slave same imei 135*** and i try to change same problem can you help me to my problem sir thanks....
Old 07-26-2008, 12:33   #6 (permalink)
Member: 130995
What is the problem with 2nd imei exactly ?
I do not see any problem explanation regarding 2nd imei
Old 07-27-2008, 02:22   #7 (permalink)
Member: 229636
Thanks Meter: 48
Unhappy
sir 2nd or slave imei starting in 13590**** and i try to change same problem sir 13590***** compare 1st or standard imei starting 13590**** and i change imei now in 1st or standard imei starting 3590**** . pls help me sir thanks
Old 07-27-2008, 10:03   #8 (permalink)
Member: 130995
Hello,
What is the problem with 2nd imei ?
Did you tried to use different imei repair methods ?
Old 08-02-2008, 16:04   #9 (permalink)
Member: 229636
Thanks Meter: 48
sir i try mode 1 not detect, i try mode 2 working for standard/master imei then i try mode 3 working but same imei output even do say successfull and i try to follow this procedure cannot power on more that 30 sec already what i need to do for slave /2nd imei same starting 135**** pls help me ask soon ask posible cause customer already mad with me
What to do:
1. Power-On phone
2. wait 20-30 sec
2. Power-On phone
3. wait 20-30 sec
Iphone 3g 2.2.1 Imei Unknown Iccid Unknown- Plz help suji iPhone 2 / iPhone 3G / iPhone 3GS 20 12-25-2009 10:24
K790 dead phone colour is unknown plz help vijaykumarmehta MT-BOX 2 03-13-2009 14:53
PIN Unknown, Please help me. coolgsm007 BlackBerry (RIM) 6 01-27-2009 15:33
please upload files of K288i kinlong chinaphone help me!!! yanaji SpiderMan 2 01-23-2009 03:17
when connect dead gx17 it says unknown device help plz jawad8305 Sharp 8 03-25-2007 12:59
Page generated in 0.39748 seconds with 9 queries
