06-08-2016, 06:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Unknown structure detected! Check correct model selection! Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_TShark_MPII_W15.51_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 12-12-2015 08:51:57 Phone Security Info : IMEI [1] : 911480003515782 IMEI [2] : 911480003515790 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.835 V Done Reconnect Power/Cable! Without Alternative LDR Mode Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! With Alternative LDR Mode Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00.00.25 Reconnect Power/Cable! Without Alternative LDR Mode Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! With Alternative LDR Mode Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00.00.32 Reconnect Power/Cable! BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! SP SC77xx[Model Select] Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00.00.07 Reconnect Power/Cable! Code: SLDR Load Ok BB CPU : SC773x SC773x eMMC v3.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v3.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00.00.23 Reconnect Power/Cable! Code: SLDR Load Ok BB CPU : SC7731 SC7731 eMMC UMS 4G512M v2 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Code: SLDR Load Ok BB CPU : SC7731 SC7731 eMMC 4G512M v1 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
06-08-2016, 10:19 | #7 (permalink) | |
Member: 621121 Status: Offline Thanks Meter: 366 | Quote: Code: Loading : Micromax_Q346_SW_V009_HW_V2.0_20160114.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Micromax_Q346_SW_V009_HW_V2.0_20160114 FastCheck : 0x006A83516D Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7731_UMS.xml Load Ok! Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q346 Model Brand : Micromax Model Device: Q346 AndrVersion : 5.1 BaseBand CPU: Q346 CompileDate : 19-04-16 AM 6.04.31 Project Ver : Micromax_Q346_BD_SW_V004_HW_V1.0_20160419 Model Ext : Micromax Q346 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00.00.14 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Failed! Error_Info : DVL Failed , If it Android 5.x - Root Required :( | |
06-11-2016, 11:57 | #10 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | File size is large Problem solved after re-root Code: Loading : Micromax_Q346_SW_V009_HW_V2.0_20160114.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Micromax_Q346_SW_V009_HW_V2.0_20160114 FastCheck : 0x006A83516D Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7731_UMS.xml Load Ok! Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q346 Model Brand : Micromax Model Device: Q346 AndrVersion : 5.1 BaseBand CPU: Q346 CompileDate : 19-04-16 AM 6.04.31 Project Ver : Micromax_Q346_BD_SW_V004_HW_V1.0_20160419 Model Ext : Micromax Q346 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00.00.30 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : Q346 Model Brand : Micromax Model Device: Q346 AndrVersion : 5.1 BaseBand CPU: Q346 Project Ver : Micromax_Q346_BD_SW_V004_HW_V1.0_20160419 Model Ext : Micromax Q346 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1711 MiB Saved to : E:\All Flash file\Android\China\Micromax\Q346\Q346_Q346_5.1_Micromax_Q346_BD_SW_V004_HW_V1.0_20160419_Micromax_Q346\ Done! Elapsed: 00.16.31 Reconnect Power/Cable! |
