07-12-2008, 14:48 | #1 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | unlock alcatel s210 successfull ****************** COM3 [VCP0] selected Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-E221_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\backup_Alcatel-E221_eeprom_calibration-1_20080712-153752.80E.bin Read data done Check data... Check data done Writing... .......... .......... ... flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 66 sec Remove/Install battery now ! ***************** his connector like moto v3; & Also successfuly found pinouts for it with pinfinder. software version: 1.10 cable type: 1x5 (L5A) platform: TI: Hercules, Calypso, Locosto searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... result: Rx:4 Tx:3 time required: 7 sec Power On ! br |
The Following 9 Users Say Thank You to zinoubinabil For This Useful Post: |
07-24-2008, 05:15 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: 13 00 N, 122 00 E (PH)
Member: 3156 Status: Offline Thanks Meter: 63 | thats perfectly what im looking for, sir could you please post the right pinout with regards to orientation. pin 3-4 left or right top or bottom? thanx! |
The Following User Says Thank You to d_bug For This Useful Post: |
07-24-2008, 07:25 | #6 (permalink) | |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
this is the correct pinout Cable name: ZTE-7310 connector_usb_mini-5.gif keyboard top _____ /12345\ _______ 1: Gnd 3: phone Rx (RJ45 pin-2) 4: phone Tx (RJ45 pin-3) | |
The Following 7 Users Say Thank You to zinoubinabil For This Useful Post: |
10-26-2008, 15:00 | #8 (permalink) |
Freak Poster Join Date: Jan 2005 Location: india
Member: 102598 Status: Offline Thanks Meter: 68 | COM3 [VCP0] selected module v1.28 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail Finished, time used: 12 sec Remove/Install battery now ! |
unlock alcatel s210 problem | gsmplus08 | Infinity-Box | 3 | 04-06-2009 19:06 |
Successfully Unlocked Alcatel S210 | toto05 | Infinity-Box | 4 | 01-26-2009 12:25 |
Alcatel s210 sfr from france unlock successfull by yasermalik | yasermalik | Infinity-Box | 15 | 01-14-2009 04:41 |
succesfully unlock alcatel s210 with infinity+pinfinder | Haouas | Infinity-Box | 1 | 07-26-2008 20:33 |
