06-24-2011, 20:37
#1 (permalink)
Crazy Poster
Member: 900802
Thanks Meter: 156 | unlock blu Q200 no work unlock blu q200 no work. thanks
log Quote:
==== [24/06/2011 15:00:12] ====
COM3 [VCP0] selected
modulo v3.96
Action: read unlock codes
Metodo unlock: read codes
Modelo: Blu-Q200
Checkeando datos, espere...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
19200 autodetect
Iniciando [6253:8A02:8A00]...
CPU: MT6253
alta velocidad de boot On
chip: 0000:0000:000F
status: FF
Connecting at 19200, wait...
Deje de presionar el boton power ahora !
Telefono detectado, espere...
Hardware: MT6253,E02
Dato: 2000.00.00
Version: 1.0
Version: X221_6E_DB_VV_V001_110402
Version: HEXING53_09A_GEMINI_HW
86 byte(s) read
imei: 35868800000015
coneccion Ok
192 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
180 byte(s) read
Leyendo datos...
188 byte(s) read
lock[1] code: + default
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- insert wrong sim card into phone
- power-On phone
- enter code: 12345678
- wait 10 seconds
- power-Off phone via "Power" button (do not remove battery)
- read unlock codes again
Finalizado, tiempo usado: 16 sec
Quite/coloque la bateria ahora !
Cargando Archivo v.02...
Blu-Q200_HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X22 1_6E_DB_VV_V001_110402.BIN_FLNS71VS128RC0AHK4L0__f irmware_20110624-140904.B0M.bin loaded
usb bootloader (file) is absent
rom info ver: 07
sw version: HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X221_6E_ DB_VV_V001_110402.BIN_FLNS71VS128RC0AHK4L0
project-id: X221_6E_DB_VV_V001_110402, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
rom info structure: [standard] type (07)
TCL-ID is absent
firmware date/time: 2011-04-02 18-12
hw1: HEXING53_09A_GEMINI_HW
==== [24/06/2011 14:22:32] ====
modulo v3.96
Action: "sp-unlock"
Metodo unlock: smart fast
Modelo: Blu-Q200
19200 autodetect
CPU: MT6253
status: FF
Dato: 2000.00.00
Version: 1.0
86 byte(s) read
imei: 35488204223271
coneccion Ok
192 byte(s) read
Leyendo datos...
reading data #2...
construcción de nuevos datos..
escribiendo datos...
180 byte(s) read
Leyendo datos...
188 byte(s) read
verifying...
verificacion Ok
Listo
Finalizado, tiempo usado: 23 sec
==== [24/06/2011 15:03:01] ====
modulo v3.96
Servicio: Blu-Q200
Habilitada la deteccion avanzada del chip
Action: "sp-unlock"
Metodo unlock: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Conectando, espere...
CPU: MT6253
status: FF
Tamaño del boot packet: 0400
En caso de problemas con la conexion inincial: on/off "Autoseleccionar Boot baudrate"
Boot Fail
Finalizado, tiempo usado: 17 sec
