01-21-2009, 17:59 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | Unlock digibee g240 aircell tamilnaadu Here is the PCB picture>>>>>>>> scan0001.jpg CPU :7880 1.3G 203 G832 FLASH:SPANSION 71GL032A40BFW0F 807PPJ11 L MALAYSIA |
The Following User Says Thank You to aikonmani For This Useful Post: |
01-21-2009, 18:59 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you can find a pinout you can try to read flash from this model like ZTE-225. If you will be able to read full flash we will try to add unlock support for this model. Send full flash backup to [email protected] |
01-21-2009, 19:50 | #3 (permalink) | |
Member: 304090 Status: Offline Thanks Meter: 210 | Quote:
Just select Digibee-BSNL-G200CF in pana01 v1.61 and do sp unlock... Thats all.......... This Model is 4mb infinion 7880 cpu.... Pinout is here>>>>>> Pinout...For DIGIBEE G240 FM AIRCEL..... ---------------- DIGIBEE G240 INFINITY PINOUT.JPG GND=2 RX=9 TX=7 Thanks to Infinity! And...Here is the successful log>>>>>> COM21 [Serial2] selected module v1.61 Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090121-233234.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090121-233234.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090121-233240.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20090121-233252.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 49 sec Remove/Install battery now ! G225 is another model...comes with locked to Aircel Network...... Anybody try and post here...... Again great thanks to INFINITY! | |
The Following 4 Users Say Thank You to aikonmani For This Useful Post: |
01-21-2009, 20:10 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @aikonmani Thanks for information ! Anyway, if you have some time, please read full flash from this phone and send full flash backup to [email protected] Thank you ! |
01-22-2009, 13:57 | #5 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | another one here software version: 1.17 cable type: 2x5 (L10C) platform: PMB: Infineon e-gold searching adapter at COM6... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:5 Tx:4 time required: 17 sec Power On ! saved: aircel module v1.60 Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090122-181134.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090122-181135.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090122-181141.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20090122-181153.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 49 sec |
The Following 3 Users Say Thank You to maximas007 For This Useful Post: |
01-22-2009, 15:18 | #6 (permalink) |
Member: 304090 Status: Offline Thanks Meter: 210 | @maximas75 If u got G225 to unlock try and post here..... Before unlock get full backup from phone.... thks.. |
01-22-2009, 19:19 | #7 (permalink) | |
I've sent the flash backup of DIGIBEE G240 files to [email protected]... Always we are ready to help our INFINITY! | |
01-23-2009, 16:09 | #8 (permalink) |
Member: 433257 Status: Offline Thanks Meter: 43 | and the best part of that unlocking was that how easily pinfinder detected the pinouts at ease. just select infenion e-gold and detect the pinout |
The Following User Says Thank You to maximas007 For This Useful Post: |
aircel digibee G225 CAN UNLOCK???????? | jothi737 | Infinity-Box | 11 | 11-29-2011 10:34 |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
DIGIBEE G240 Pinout | aikonmani | CPF-BOX Ⅱ | 0 | 01-22-2009 19:26 |
unlocking LG-cg225 | cellrepairus | NSPRO | 0 | 04-30-2008 22:37 |
