unlock error Tmobile energy hello please help me, here is the information Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6236, E02 Hardware version: BYD36_10A_HW Software version: U5.6NT01V01.08" Software date: 2000.00.00 Barcode: 0317024C23177453 0601 CID: b4a766ca03a74f19c7416f97c22b77f2"OK Lock: AT+LOCKSTAT?ERROR imei-1: 861132001810786 Finished, time used: 4 sec Remove/Install battery now ! calculation from calculator Checking data, wait... Device: T-Mobile-Energy imei: 861132001810786 cid: b4a766ca03a74f19c7416f97c22b77f2 NCK: 29990597 can you please tell me what is wrong the code calculated is not accepting and it says wrong code please please help me |
It may be that unlock tries counter was blocked due to wrong codes was entered so many times. You can try to reset phone to it's factory state (f.e. power-on phone with * + # pressed together) and then try to unlock phone again. also you can try to unlock phone directly (smart-fast unlock method) with latest MModule software. |
Where can I find drivers to unlock this phone? I connect it via USB powered on but it ask for G7300 drivers. Thanks |
Please can someone tell me procedure to unlock the Tmobile Energy G7300 and where can I find drives ? Thanks |
You have to use Rx/Tg/Gnd cable. Connect cable, run software, select model, click to SP-Unlock button. |
