02-27-2010, 18:13
#3 (permalink)
Member: 264903
Sonork: 1584531 Thanks Meter: 3,350 | 100% Unlock Vodafone 541 Quote:
COM72 [VCP1] selected
module v3.16
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001503:A00F
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: D:\Arquivos de programas\InfinityBox\MModule\backup_security\id.4 9018FED.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 49018FED
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 17B
provider: 708X-2EVDPT1
customization: CN17FG72
customization: XN17FG72
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35400703501615
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: D:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_49018FED_E8F450A0_20100227-141210.B0X.bin
Finished, time used: 4 min 18 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
| Thanks Support infinty
LuisinhoCell |
