11-20-2008, 20:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Tanzania but U cant see me !!! Age: 43
Member: 228601 Status: Offline Thanks Meter: 56 | thanx infinity lobster alca s621x unlocked ==== log: [2008-11-20 05:21:11] ==== COM3 [VCP0] selected module v2.43 Device: Alcatel-OT-S621X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:5E03:A00D boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.30507 C2F.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: 30507C2F identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35198902012313 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_30507C2F_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20081120-052158.B0X.bin Area: Firmware flash: 01227E22442200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_30507C2F_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20081120-052328.B0X.bin Finished, time used: 132 sec Remove/Install ba |
The Following User Says Thank You to david laborator For This Useful Post: |
11-20-2008, 22:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
03-07-2009, 00:23 | #3 (permalink) | |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | Quote:
hi infinity team got problem with s621x unlocking,alredy done lots of handsets,but i got one of them with me,after flash simfree flash file on it phone works fine bt blank screen,alredy flash with another file.bt same problem.phone was ok but after flash file phone got blank screen. any help on it. thnx | |
03-08-2009, 22:08 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to flash phone with latest firmware: S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M.bin Phone will be locked back but should be no problem with LCD. Waiting for your results. |
03-09-2009, 15:22 | #5 (permalink) | |
already done,phone cumup again to normal,but is there any solution or any trick for unlock this firmware? | |
03-09-2009, 16:31 | #6 (permalink) |
Junior Member Join Date: Mar 2008 Location: GHANA
Member: 731389 Status: Offline Thanks Meter: 0 | hello pls i have problem with sonyericssion t303 any time i connet this is the errow it gives me pls help me out hope to hear from u soon COM6 [VCP0] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 47 sec |
03-09-2009, 18:42 | #7 (permalink) | |
this is s1 naptune phone with new security,so u can unlock those phone with server taking credit,use setool server or seking server or ub box for unlocking. | |
03-09-2009, 19:43 | #8 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | @mr.fone We will try to make unlock solution for this new hardware type as soon as possible |
The Following User Says Thank You to InfinityN For This Useful Post: |
lobster S621x unlock ? | waqas_ali601200 | FuriousGold | 3 | 05-08-2010 13:19 |
Thanx Infinity team Great work for this update:::Ufone new security Unlock T156:::: | mutewitness_akp | Infinity-Box | 0 | 12-09-2009 14:27 |
ot-s621 lobster s621x unlocking needed | rajeshbahri | Infinity-Box | 4 | 04-06-2009 18:37 |
lobster s621, alcatel s621x unlocked with 100% success | Umair Rashid | Infinity-Box | 9 | 04-04-2009 12:53 |
Lobster S621x Unlock After dead | jubaer | Infinity-Box | 10 | 04-03-2009 18:13 |
