Old 02-02-2009, 03:26   #1 (permalink)
Member: 185119
Thanks Meter: 91
Talking unlock ke770 done.......
COM38 [VCP0] selected
Device: LG-KE770
Checking data, wait...
Action: unlock
direct unlock
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0089:88B0
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta_20090202-101851.B1E.bin
reading [eeprom-sta2]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta2_20090202-101853.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading [eeprom-sec_35030526000000100]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sec_35030526000000100_20090202-101854.B1E.bin
reading [eeprom-complete_35030526000000100]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-complete_35030526000000100_20090202-101856.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 01E6
Done
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 23 sec
tnx infinity......
The Following 2 Users Say Thank You to 99026 For This Useful Post:
Old 02-02-2009, 05:03   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Device: LG-KE770
Action: unlock
direct unlock
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0089:88B0
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
loading data...
data loaded
Check memory...
Check memory Done
Write...
Verifying...
Verify result: 01E6
Done
Write Done
Time used: 23 sec
tnx infinity......
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 02-02-2009, 07:13   #3 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
thanks br good work ..........
Old 04-26-2009, 00:17   #4 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
Thanks Meter: 91
Another Post
COM2 [VCP0] selected
module v1.60
Device: LG-KE770
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0089:88B0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-static_20090426-001633.B1E.bin
reading eeprom-static2...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-static2_20090426-001634.B1E.bin
loading data...
data loaded
reading eeprom-security_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-security_35030526000000100_20090426-001636.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-complete_35030526000000100_20090426-001639.B1E.bin
Check memory ...
Check memory Done
Write ...
Verifying...
Verify result: 0185
Done
Write Done
Finished, time used: 27 sec
enjoy all
The Following User Says Thank You to G$m For This Useful Post:
Old 04-26-2009, 12:11   #5 (permalink)
Member: 128745
Thanks Meter: 16,850
thankyou for your good test reports
Old 09-03-2009, 02:27   #6 (permalink)
Member: 756093
Sonork: 20100
Thanks Meter: 2
Ke770 its ok unlock whith infinity box
Logs Consumed unlock not done. Now need logs to unlock mishaelwillo Universalbox 1 09-04-2009 01:50
z3x can not unlock ke770 cityyemen Z3X-Team Products 2 07-26-2009 14:36
err help! unlocking---kinda done :-\ Gremlinbt Panasonic 1 07-19-2003 13:00
Page generated in 0.32647 seconds with 8 queries
